Rattling Noise from the Heat Shield - Throw it away?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dhman2006, May 13, 2017.
  1. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    I've been hearing a little rattling noise from my car for a few days now. At the beginning I wasn't sure what the noise was, but today I jacked up the car, crawled underneath, and found out that the heat shield that goes above the middle section of the exhaust pipe has come loose. Does anyone know how important that heat shield is? Do I need to repair it or can I throw it away? One of my coworkers told me to throw it away ... apparently that's what he did with his.
    What do you folks think?
  2. Mendel Leisk
    38,648
    Never throw out anything. Just thank the automotive gods that it's at least still there. It does serve a purpose, best not to second guess it. Replacement cost for all these things is basically: take the most ridiculously exhorbitant cost you can dream up, then double it.
    Figure out why it's rattling. Maybe a missing bolt? More likely the bolt is still there, but the shield snagged on something and tore off the bolt, enlarging the hole? Get it raised, DIY if you can safely, and see what's going on.
    If it's a torn out hole, and the bolt is still there, at hardware stores you can pick up oversized washers: have larger outside diameter than usual, will span the torn hole. Bring in the bolt to check fit.
    ALS and Raytheeagle like this.
  3. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    Left side of the shield is rusted out and just came off the bolt. The bolt is still there, but the piece that was holding onto the bolt got rusted and can't be hold onto by the bolt anymore.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Temperatures in that area of the car are hot due to combustion. I would look for a salvage part if what remains will not work or cannot be cobbled together to work.
    IMO, replace the shield;).
    #4 Raytheeagle, May 13, 2017
  5. Mendel Leisk
    38,648
    If the tear is too big for over-sized washer, my next ploy would be a short piece of galvanized pipe hanger, again, just acting as a washer at the tear-out zone:
  6. Tande
    Tande Active Member
    502
    302
    Mich.
    FWIW....mine did the same thing at about 100,000 mi. .......I repaired it just as Mendel described in post #2.....
    Raytheeagle likes this.
  7. Kenny94945
    Kenny94945 Active Member
    780
    397
    Sausalito
    2016 Prius v wagon
    see post 4.
    I would attempt a repair with what ever product...hanger, washers, sheet metal, nuts and bolts
    Good luck.
  8. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    This looks like it would work...
  9. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Yep $200 including labor. That is what I paid the dealer last month when mine came loose.
  10. goodwheelz
    goodwheelz Junior Member
    CT
    I tried a few solutions. The easiest was to put two pairs of 2 Harbor Freight steel cable ties through the hole and around the bracket above the heat shield. I positioned one band going through the whole and to the right and the other band going through the whole and to the left to provide a counter pressure on each side.
    Total Repair Cost: $6.99
  11. HammerGrips
    HammerGrips Junior Member
    Traverse City, MI
    Mine is now doing the same. I'm thinking I will just tear it off, assuming it's easier than reattachment. If you think about a Prius going down the road, there should be plenty of airflow. Sitting or slow traffic, the engine's not running.
  12. Mendel Leisk
    38,648
    Get some fender washers; make it last.
