Rattling under parking brake
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by beetnerk, Oct 26, 2021.
  1. beetnerk
    beetnerk New Member
    Sunday I was driving back home from a trip on the highway when a semi in front of me brake-checked me at 70 mph and I saw my life flash before my eyes. I tried to slam on the brakes as little as possible but of course the tires put out the burnt rubber smell. Obviously, this is not at all an idea braking scenario (especially since I am almost obsessive about conserving the most of the regenerative braking and optimizing my gas mileage) but the brakes should not have been compromised just from a hard brake. After the truck resumed moving and I was able to drive my Prius C again, there was a grinding (closer to marbles rattling, like a plastic piece was loose and hitting another plastic piece in parking brake area). I had to get home the rest of the way, so I was able to tell that the noise was coming from closer to the passenger seat side of under the barking brake lever, but I've been scared to drive it since then and getting under my car hasn't shown anything to be wrong. I don't know of any mechanics around who specialize in Toyota or hybrids, but I guess pretty soon I'll just have to settle for another mechanic since I have to drive. Any guesses? It's a 2013, I just bought it used in late August and it's had no problems. I check all the fluid levels weekly or biweekly and have so far done all the routine maintenance (outside of tire rotation) myself. OD is 132k.
  2. beetnerk
    beetnerk New Member
    Update: The rattling only occurs when the engine engages, and only for a few seconds after. It almost sounds like something is loose. I just had my oil changed and tires rotated + fluid topped off (at Jiffy Lube though, so wouldn't be surprised if they didn't top anything off at all because the car wasn't vacuumed as advertised either and they forgot to put my hubcaps back on) The sound definitely is not coming from the floor mounted transmission and I'm still getting the 50-60 mpg that I always get, including highway. I can't figure out what would be underneath the parking brake. The parking brake still is completely functional but it does sound a little louder engaging. I can't tell if the hard brake made something loosen up in the parking brake or if it's just coincidence, but the sound is unsettling and I can't figure out why the parking brake would be affected. Maybe the counter gear? It doesn't sound like grinding so much as low lubrication or a loose part, could even be part of the console if it wasn't connected to the engine kicking in (although on second thought the engine does shake the car more than the battery mode does... Still, it feels like too much noise). The sound is about the level of a whisper and I won't notice it if someone is talking or the radio is on, but I've been driving the car silent every time I've had to (home the first time and then to the mechanic) so I can try to figure out what's up. I travel alone a lot and don't have family nearby so I'm very worried about the possibility of getting stranded, especially since it's getting really cold.
  3. topshot
    topshot Member
    145
    57
    Midwest
    2015 Prius c
    Interesting your tires locked up. ABS should have prevented most of that or does the One not have that on the rear?
    Anyway, most rattling comes from exhaust system and since it happens when engine kicks in I would lean toward that, but don't know why it would consistently stop after a few seconds though since it's usually either constant, based on RPM or random in nature. I'd check for any pipes, cables, etc. that are very close to the exhaust, all the mounting hardware for the exhaust and any heat shield connections.
  4. Mendel Leisk
    41,969
    The truck hit his brakes hard, out of the blue?
  5. ChapmanF
    18,626
    "Under the parking brake pedal" to me sounds a lot like "near the left front wheel well" and I think my first instincts would be to look for something pretty simple in that neighborhood that could have been dislodged, loosened, or caught during a hard braking incident. Esoteric ideas like "counter gear" are most probably overthinking it by a lot. :)
    Maybe the truck brake-checked because of an unidentified roadway object, and he missed it and you collected it, and didn't notice because you were preoccupied with not dying?
  6. Leadfoot J. McCoalroller
    8,157
    7,660
    Pennsylvania
    2018 Prius c
    A heat shield from the exhaust can make all of those noises.
    They eventually rust and fall off. The car is born with several, protecting pipes that run approximately down the middle of the car's belly. Maybe this one is only halfway there, the hard braking knocked it loose etc.
    That's an educated guess- somebody needs to get under there and look.
    CosmicWunderkind likes this.
  7. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    If there is any concern, take it to a Toyota dealer or a local mechanic.
    Please do not rely on jiffy cause they will give a diffy of what you want and pay for. :eek:
    I would have concern to, as I have 50k on my current c and maybe 30k+ on my last c and
    I do not recall ever locking up tires or getting burnt rubber smell from any hard braking.
    Can you distinguish from rubber tire smell and brake pad/shoes smell? Only curious.
    May have been smelling the trucks tires/brakes also....
    I agree that it is a heat shield or something.
    If you are able to scooch ? under the car when it is cool (not hot after driving) you can reach
    your hand and tap and fiddle with everything under it, by the muffler and shield(s)
    The parking brake is a hand brake in the center between front seats and would have a bit of sound leaking from outside.
    edit: this member has not been back since the update (2nd) post
  8. ChapmanF
    18,626
    Oh right, I forgot the c relocated the parking brake to a hand lever. That puts it nearer the exhaust heat shields and stuff.
  9. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Lots of times after I drove the Gen3 or now with Prime, I will hop in my loved c and stomp with my left foot once or twice
    until realizing oh...
