RAV4 EV revisited
Discussion in 'EV (Electric Vehicle) Discussion' started by C.RICKEY HIROSE, Apr 18, 2008.
  1. C.RICKEY HIROSE
    210
    S.F. BAY AREA CALIFORNIA
    The Rav4 EV brings my memory lane back to the future.
    I could not buy/lease one of the wonderfull RAV4EV back then.
    I recall,the doctrine was no Toyota employees allowed,
    all goes to general public only and reserved!
    I did make a lot of current owners happy although, They all say,
    will buy/lease another one if Toyota will bring them back.
    GM should have kept the EV1 in the market.
    Toyota should have kept evolving the wounderful EV technology.
    Toyota RAV4 EV
    From Wikipedia, the free encyclopedia
    Jump to: navigation, search
    Toyota RAV4EV
    The Toyota RAV4 EV is an all-electric version of the popular RAV4 SUV. It is powered exclusively by NiMH batteries.
    Contents
    [hide]
    Performance
    The RAV4EV has a governed top speed of 78 miles per hour (126 km/h), a tested 0-60 time of around 18 seconds (depending on state-of-charge on the batteries) and a range of 80 to 120 miles (130 to 190 km). Mileage depends on the same factors as a traditional gasoline-powered vehicle, mainly rolling resistance and average speed (aerodynamic drag).
    The RAV4EV has 24 12-volt 95Ah NiMH batteries capable of storing 27.4kWh of energy.
    Charging
    The RAV4EV's batteries can be recharged from being fully depleted to fully charged in about 5 hours. Charging is supplied via magnetic induction by a wall-mounted 6000-Watt charging unit on a 220 volt, 30 amp, North American "clothes dryer"-type plug. The process of connecting the RAV4 EV to the home charger is as follows:
    • The driver parks the RAV4 EV with the vehicle's grille within 8 feet of the charger (usually the back wall of a garage).
    • The ignition is turned to 'off'.
    • A button is pressed on the dashboard that opens a door built into the RAV4 EV's grille.
    • The driver removes the cabled inductive charging paddle from the wall charger and inserts it into a receptacle behind the grille door.
    • The charger checks the connection automatically, and charges the RAV4 EV
    This process is nearly identical to the process used to refuel a gasoline-powered car at a gas station pump, the only difference being the pump nozzle is a paddle shape, you can charge the vehicle at your home or other location, and the receptacle is in the RAV4 EV's front grille, instead of a gas tank towards the rear.
    The time used to connect the RAV4 EV to the charger is approximately 2-3 seconds, when standing at the front of the vehicle.
    Mileage Costs
    As of May, 2006, charging an RAV4EV from full-dead to full-charge, at a rate of US$0.09 per kilowatt-hour, costs around $2.70. As of December, 2007, based on a gasoline price-per-gallon cost of US$3.25 and up. and the non-EV 2003 RAV4 2-wheel-drive gasoline fuel efficiency of 27 mpg, the RAV4EV costs approximately 25% as much to fully charge, and makes mileage in the RAV4EV the cost equivalent to a 111.1-mile-per-gallon small SUV (2.12 L/100 km).
    In addition, the RAV4EV has a charge timer built into the dashboard that enables the vehicle to start charging at a specific time. As the RAV4EV easily becomes the main cost of electricity in an average-sized home, this enables the owner to use a Time-Of-Day Meter to reduce electricity costs. This configuration is a standard practice with RAV4EV owners. The price of electricity at night depends on the carrier, but is usually in the range of 60% of the normal rate. In the use of charging the RAV4EV, this equates to a cheaper cost-per-mile, roughly equivalent to a vehicle capable of 166.6 mpg (miles-per-gallon) (1.41 L/100 km), based on a price of US$3.00 per gallon.
    The United States Environmental Protection Agency listed mileage ratings for the RAV4EV in its yearly Fuel Economy Guide from 2000 through 2003. The 2003 model recorded city mileage equivalent to 125 mpg, and 100 mpg on the highway. Estimated combined mileage was 112 mpg.
    For comparison, a reasonably modern European supermini may manage motorway travel at 5 L/100 km (47 mpg US) or 6.5 L/100 km in city traffic (36 mpg US), while an average North American mid-size car travels 9 L/100 km (27 mpg US) highway, 11 L/100 km (21 mpg US) city.
    Wearable Items
    The RAV4EV's battery system is a wearable item. Third party battery vendors charged approximately US$26,000 as of June 2007 on eBay for replacement packs. Toyota tested the RAV4EV in Japan for 300,000 miles over two years before introducing the vehicle in the United States. It should be noted that the economies of scale are affecting the replacement cost of the RAV4EV.
    The remaining systems in the RAV4EV are comparable to the gas-powered RAV4, such as power brakes, power steering, air conditioning, tire wear and suspension components.
    source: Toyota RAV4 EV - Wikipedia, the free encyclopedia
  2. thecoook
    thecoook Junior Member
    38
    Sanford, FL
    Last night I was watching a YouTube video about an EV-1 that had been donated to a University and was now being shown at an EV exhibition, what I found so weird is that GM destructively DISABLED these donted vehicles before its delivery to schools and then made them promise that it was NEVER to be used as an EV again! How WARPED is that?
    I guess the EV-1 is begiining to grow on me now, although back then it didn't make any sense with gas at a buck-a-gallon and a 60-80 mile range. I love the contours of the vehicle, very sleek, and the employees involved with the project were very enthusiastic about it.
    Oh well, I'm just glad I got our 2008 Prius.
  3. blazer_5154
    blazer_5154 Heh, you said "member"
    106
    Maryland
    There was one on display for a while at the Smithsonian that had not been "Destructively disabled", it only had the batteries removed because the Smithsonian would not accept it in an "altered" state. Sadly, it was removed from display about 2 years ago and was replaced by "Stanley", the the autonomous VW Tourag (sp?) that won the DARPA challenge years ago. I'm sure that it is still moth-balled in the vast storage warehouses of the Smithsonian just like the ark of the covenant. :hurt:
  4. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    "I'm sure that it is still moth-balled in the vast storage warehouses of the Smithsonian just like the ark of the covenant. "
    Is that what the new Indiana Jones 4 is about, finding the last intact EV-1 in captivity?
  5. hill
    8,070
    If I had a buck for every low mile rav4-ev I've bid on thru ebay since 2003, I'd have a nice part of the payment done ... even tho battery replacement / reconditioning will be an issue.
  6. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    Here's another piece for the archive, the official DOE test sheet:
    avt.inl.gov/pdf/fsev/eva/toyrav98.pdf (sorry can't link right now)
    Rob
  7. darelldd
    6,057
    388
    Northern CA
    Whoa. What happend to my reply? Tried twice now!
    Are the links the problem? Crazy.
    Anyway... here is the relevant info from my site.
    Let's try: evnut dot com/rav.htm
    And: evnut dot com/ev1.htm
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    Yea, there's a bug not allowing hyperlinks right now.
  9. darelldd
    6,057
    388
    Northern CA
    Ah! I guess that explains that entire wiki page paste above! Ever since the PC issues became serious, I just stayed away... didn't know what was going on!
  10. thecoook
    38
    Sanford, FL
    Since getting our 08 Prius, I've become fascinated with the Hybrid setup and Electrics, so I bought "The car that could" and "Who killed the Electric Car" from Amazon. Wow, what a story! The book and the DVD compliment one another. I still cannot fathom WHY the EV1 HAD to be destroyed! What ever happened to the GM-Toyota NUMMI collaboration? It seems to be a long-range, deep-enough pockets quandry that has plagued GM since the 80's. Apparently the new Volt will be smooth and flowing, not angular Camaro-ish like the concept. It would be so neat to see a second gen EV1 (EV2?) with a Hybrid setup.
  11. jtmhog
    jtmhog Member
    151
    I've seen the movie but, haven't read the book. The movie is highly biased against GM for destroying the EV1s. GM had to rent the cars because not many people would buy them at 50K. They were loosing millions on the EV1 program. What should a company do with a product that looses money and has no chance of ever making money--get rid of it. That's what they did. The market did not generate the demand for the electric car at that time; the CARB regulation requiring 10% of cars sold in CA to have zero emission required the car manufacturers to make EV cars. The car companies got together and had the regulation canceled. The EVs of the nineties disappeared. In the next 10-20 years there will be a gigantic change in the auto market place caused by the rising fuel prices and the US car companies are going to miss the boat. There are 3 new EVs being sold--Tesla, Smart and Think--all being built outside the US.
  12. Flying White Dutchman
    4,374
    313
    i have seen the movie to and maybe you can recall that people wanted to pay good money for these cars and even except the fact that GM wil no longer service warranty them..
    so there was no need to get rid of them!
  13. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I thought that was what GM said about hybrids when the Prius came out. Correct me if I am wrong here.
  14. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
  15. daniel
    14,487
    1,518
    Spokane, WA
    Emphasis mine.
    Where the above argument is flawed is that we are talking about cars that were already on the road, being driven by people who were willing to pay additional money to keep them and to sign away any right to warranty or service, and which were worth nothing to GM. In fact, GM spent additional money to recall and crush them, when it could have reduced its losses by letting the leasees keep the cars.
    This was clearly not a case of GM cutting its losses. This was GM taking extraordinary action, at great additional cost, to get electric cars out of the public sight.
  16. Rakimb17
    Rakimb17 Junior Member
    48
    Palmdale CA
    How much is GM spending on Hydrogen and Flex Fuel? And hybrids with small battery packs?
  17. McDonald
    McDonald New Member
    264
    Boston, MA
    I also check eBay to see the Rav4 EV's, how much they go for, etc. I wish they still made them, they seem to be the best of all worlds. Ugh!
  18. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    GM and the other American car companies are in bed with the oil companies--if you believe that, then what they do makes sense.
    The irony, of course, is the current explosion in oil prices hurts the car companies and helps the oil companies. This is more evidence that oil prices right now are caused by overspeculation--not caused by the oil companies--though they benefit.
  19. daniel
    14,487
    1,518
    Spokane, WA
    To say the auto makers are "in bed" with the oil companies suggests some kind of conspiracy. The truth is much more mundane: The auto makers own big chunks of stock in the oil companies and the oil companies own big chunks of stock in the auto makers, and they have interlocking boards of directors.
    They are not "in bed with" each other. They ARE each other. The auto makers and the oil companies are, for all practical purposes, the SAME companies. You cannot "conspire" with yourself!
    But the rising cost of oil will drive a return to EVs. The American auto makers may choose to ignore the writing on the wall and go out of business. But gasoline is on its last legs. Even our lovely Priuses will be obsolete soon.
