RDS jumbles
Discussion in 'Gen 2 Prius Main Forum' started by timbobo3, Sep 4, 2008.
  1. timbobo3
    timbobo3 Junior Member
    16
    Has anyone had gremlins in their RDS? I have stations that I know DON'T have RDS showing song names and the song/artist names are sometimes scrambled on all stations...or they are frozen and don't update. What did your service entail? Replacement of the radio/receiver unit?
    I have an '07 with 13k miles.
  2. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    No RDS trouble on my 2006 with 61000km. Keep in mind though that some stations just transmit poorly formatted RDS data that can confuse some receivers. Your best bet is to go to your dealer, park two Prii next to each other and tune to the same station. Check the display to see what RDS data is being read in. If there are errors and your FM reception is fine otherwise, push to have the radio tuner unit replaced under warranty. An RDS FM receiver has a traditional analog section you listen to and a digital section that decodes RDS data. A fault in the tuner that separates the RDS data could feed the RDS data decoder chip with a garbage signal. (assuming the data was transmitted correctly in the first place...)
    Check these out:
    Radio Data System - Wikipedia, the free encyclopedia
    HowStuffWorks "How is my radio able to display the station's call letters?"
  3. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    i think you can rule out the radio by tuning to different radio stations. or try "msg" ?
    lately kufx has been sending out the rds tag "angie" and its been stuck on "angie" for a while
    yeah other then replacing the radio if needed or changing the antenna out, i can't think of any other way to trouble shoot it, instead of what other people have mentioned
  4. timbobo3
    16
    thanks...I think it's the radio digitial part because a neighbor with a new Prius does not have the problem.
  5. rigormortis
    1,340
    26
    san jose, ca
    yeah if its under warranty just make them order you a new one
