Re-charging PiP traction battery while driving
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by freedom45, Aug 11, 2012.
  1. freedom45
    freedom45 New Member
    24
    Montreal, Quebec, Canada
    Does anyone know how much of the traction battery can you recharge while driving long distances ?
    So, once the traction battery is fully depleted, can you actually fully recharge it if you are driving long distances at highway speed ? if so, how long does it take to fully recharge the battery.
    Thanks,
    Dan
    51,155
    you can fully recharge the battery, but not on the highway. it isn't programmed to do that. it wouold use more gas than electric created. the only way to do it to a great extent is long downhill runs. there's no free lunch.:)
  3. freedom45
    24
    In my current PRIUS 2011, if I drive long enough, the traction battery gets fully recharged while driving on the highway / while the gasoline engine is on.
    If you drive very long distances on the highway (lets say 200 miles), wouldn't the traction battery be fully recharged like my current PRIUS ?
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    NOPE, I travelled from NY to Michigan on HWY got 50.2 MPG and no full EV
  5. bisco
    51,155
    i'm not sure why your current prius is fully charging on the highway. i never saw that in my 08 and have never seen it mentioned here before. perhaps it's 200 miles slightly downhill? also, that's about 1% of what it would take to fill the pip battery from empty.
  6. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I suspect it would fully charge coming down off Donner Summit (7200 ft 2200m) to Sacramento. (25ft 8m)
  7. bisco
    51,155
    should do it.
  8. markabele
    5,084
    1,782
    Nebraska
    What are you defining as full? If 60 percent is full then yes hwy speeds charge the battery to full. (in the gen3)
  9. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    No.
    Ordinary highway cruising after depletion will result in HV operation very much like the model without a plug... it will topoff to a particular kWh level, then utilize the rest for great MPG.
    And I know this firsthand, having already driven close to that distance non-stop.
  10. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    I would hazard a guess.... Since I can go from a half full, non plug in, to a maxed out HV battery with a steep 600 ft drop (ICE spinning using no gas) . I would guess a PIP would take about 2500 ft steep drop to do the same.Any one done it??? ....
  11. bisco
    51,155
    what is who defining as full? you'll have to ask the op. i define 'fully recharged' (op's words) as full bars. that would be 100% of the display and whatever of the actual battery. how can 60% of anything be full?
  12. markabele
    5,084
    1,782
    Nebraska
    because in the GenIII 60% is as full as it gets via charging from the ICE
  13. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I thought we were talking about the PIP. If we aren't, every thing I have said is wrong and I apologize for wasting your time.
  14. markabele
    5,084
    1,782
    Nebraska
    We were until post #3 where he referenced him getting a "full" charge from hwy driving in his current gen 3
  15. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I apologize for not following the thread and actually answering the OP.
  16.
  17. Sorry for the confusion on post 16.
  18. bisco
    51,155
    i see, but, 'as full as it gets' is still not full, it just won't allow it to fill anymore for whatever reason. in the pip, i ddon't think the engine will charge the battery to any great extent. 60% of the non pip battery is probably it's 'happy place'. i don't consider that full, i wonder if the op does.:)
  19. bisco
    51,155
    you didn't specifically answer the op, but you added great knowledge to the conversation.:p
  20. DLee
    DLee Junior Member
    81
    100%, but only during down hill driving.
