Re-starts by itself. Won't start. Loses 12V battery power?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusOwner428, May 19, 2026.
  1. PriusOwner428
    PriusOwner428 Junior Member
    85
    IL
    Used to be occasional, now seems to be happening every other time.
    When parking & pushing park button followed by pushing the power button to turn it off - it will appear to turn off. About 5 seconds later it will turn itself back on (or at least the MDF and dash lights appear to say it's on). Another push of the power button seems to finally really turn it off. When starting it back up the next morning the radio station pre-sets are all lost, the clock is set to 1:00, the trip mileages are set at 0. It appears as if the 12V had been disconnected. But there are no 12V battery related issues present after that or while driving. Has not displayed "12V disconnected systems" when driving yet.
    Another thing that has also started happening recently is that at times it will not start when brake is depressed & the power button is pushed. After giving up for awhile and trying again a few minutes later, it will eventually start. Pretty sure this another symptom of the same problem causing the self starting symptom. So far it eventually does start after a few attempts but concerned it will eventually not start at all. Or that 12V power might be lost wile driving.
    Any ideas of the problem and the fix for it?
  2. dolj
    dolj Senior Member
    8,646
    4,396
    Wellington, New Zealand
    Because there is no such thing. If you were to disconnect the 12 V supply while the car was READY, it would be totally fine until you turned the car off.
    The symptoms you describe are indeed a break in the 12 V supply somewhere from the 12 V battery in the back, right up to the main fuse in the front. If you've checked the connections in the back, then you need to look further afield.
  3. Brian1954
    Brian1954 Senior Member
    2,682
    1,071
    South Central PA, USA
    Start with the 12v battery. How old is the 12v battery? Is the battery fully charged? Has the 12v battery been tested to see if it is good?
    For clarity, is this the same car that you created a thread about in September 2025 ,https://priuschat.com/index.php?posts/3565547 or is this a different car?
  4. pasadena_commut
    pasadena_commut Senior Member
    3,065
    951
    Southern California
    Bad 12V battery? Next time you park it leave the hood unlatched. Before restarting the next day check the voltage between the jump point in the fuse box and any shiny bolt head. Any of the ones on the top edge of the inverter case will work, but wipe it off first, because at least on my car dirt tends to settle there.
    Does the car shut down well if you press and hold the power button? That method will work if the capacitor in the combination meter is going out. Not shutting down properly is characteristic of that problem. Not starting at all is more likely to be a weak 12V volt. It is possible I suppose to have both issues at the same time.
    Brian1954 likes this.
  5. PriusOwner428
    85
    IL
    Yes. All the symptoms point to a random/loose 12V battery connection somewhere. The fact that it happens randomly points to a loose wire. The one symptom that I don't think fits the break in the 12V supply is the occasional turning itself back on after 5 seconds.
  6. PriusOwner428
    85
    IL
    No. But this is the car I flip-flopped the 12V battery with to eliminate the 12V battery as the issue in that other car.
  7. PriusOwner428
    85
    IL
    The MDF capacitor is going out. About once a month I get the dark dash display. I'm at about 250,000 miles so figure I'll get that issue fixed at the 300,000 point within a year. Will try to remember to do the long press to see if that prevents that issue. Thanks.
  8. Brian1954
    2,682
    1,071
    This is starting to make sense to me. The bad MFD is not allowing the car to shut down properly. When this happens, the 12v battery is drained down, and you lose the radio presets, clock etc. Then the car will not start. To confirm, just use a voltmeter to check the battery voltage per post #4.
    #8 Brian1954, May 20, 2026
    PriusOwner428 likes this.
  9. PriusOwner428
    85
    IL
    Thanks for all the input so far. Just checked the ground connection on the battery. I could pretty easily twist the connector on the battery post with just my bare hand. So this weekend will clean both terminals, remove any rust and tighten the nuts. But before that will also have the battery tested at AutoZone. Not sure how old it is. Will see once I get it out if it shows any date.
  10. PriusOwner428
    85
    IL
    And when started:
  11. pasadena_commut
    3,065
    951
    Southern California
    That sort of loose connection can cause all sorts of gremlins. Might as well clean the clamp and the post, but the most likely cause for that was that the clamp was not pushed all the way down before the nut was tightened when the battery was installed. When that happens in some cases the nut can be tightened to its limit but the loop won't grip the post firmly because it's minimum radius is set to grip the bottom of the post, and the post radius farther up is too small for it. It is possible that the nut worked loose too I suppose, but if I had to bet, it would be the first issue.
  12. ChapmanF
    19,020
    Another thing that happens more often than you might expect is if there's been a history of repeatedly disconnecting and reconnecting the battery clamp, and overtightening it when reconnecting, eventually the clamp kind of bends and stretches until the nut and bolt bring the ends right together and it's still not tight on the post, even on the wide bottom part.
    That was super easy to do with the olden soft lead clamps, but is still possible even with the stamped tinned clamps Toyota uses.
  13. dolj
    dolj Senior Member
    8,646
    4,396
    I imagine you don’t really think there is a capacitor made of MDF and presume you mean MFD – Multi-Function Display – which is the screen in the middle of the dash. The capacitor that usually “goes out” is not on the MFD but rather on the Combination Meter (CM), the display in front of the driver that shows, among other things, the speed, selected gear, and fuel gauge. When that capacitor is misbehaving, the CM typically goes dark and can make the car hard to turn off.
    If you disconnect the battery, whether intentionally or, as it seems in this case, randomly and intermittently, the car remembers that it was last in the “On” state, so when power is restored, the car resumes in the “On” state. Does that fit your situation?
  14. ChapmanF
    19,020
    One of our lab assignments in electricity&magnetism in college was to make capacitors out of two sheets of foil and our E&M textbook (different numbers of pages between the foil). :)
  15. Brian1954
    2,682
    1,071
    Let me correct what I wrote in post #8,
    This is starting to make sense to me. The bad Combination Meter (CM) is not allowing the car to shut down properly. When this happens, the 12v battery is drained down, and you lose the radio presets, clock, etc. Then the car will not start. To confirm, just use a voltmeter to check the battery voltage per post #4.
  16. PriusOwner428
    85
    IL
    Yes. You imagine correctly. A typo & not remembering the CM name led to that.
    It does seem to fit the situation. First step will be to ensure the battery connections are tight and rust free since it's the easiest thing to do. Then if nothing else comes up as another easy posibility I will have to think about moving up the date on replacing that capacitor.
  17. PriusOwner428
    85
    IL
    But yet the car starts a few minutes later without having done anything to address the drained battery?
    I'm thinking the issue with the bad CM capacitor might be the reason behind both the random not starting on the first try, and the random self restart 5 seconds later. But yes, now that I have the weekend will confirm battery is not the/a cause. The car itself seemes to think the 12v is OK.
  18. pasadena_commut
    3,065
    951
    Southern California
    Actually what that screen tells you is that the inverter is working. Once the car is in READY you could literally remove the 12V from the car (without turning it off) and that screen wouldn't change.
  19. Brian1954
    2,682
    1,071
    The picture you posted, which shows 14.1V, just proves that the DC to DC converter is working properly when the car is in READY mode. It tells you nothing about the health or charge of the 12v battery. After the car is in READY mode, you can completely disconnect the 12v battery from the car, and the car will continue to work properly until you power the car off. Then, if you try to turn the car on again, it will not do so because the 12v is disconnected.
    EDIT: pasadena_commut responded 4 minutes before I made my post.
  20. PriusOwner428
    85
    IL
    Right. It probably says the alternator is working just fine. I believe this is the screen that tells me the charge on the battery.
