Read threads but still need help removing battery fan
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by elliptical22, Jul 2, 2014.
  1. elliptical22
    elliptical22 New Member
    Eau Claire, WI
    I recently purchased a 2006 prius. I came across threads on here concerning the battery cooling fan going bad due to debris. I had to clean this car quite a bit to get the dog smell and hair out of it so I am concerned about my battery overheating. I read a some articles and made an attempt to get at it and clean the fan today. I got to the point of getting the three bolts off that hold the fan. I disconnected one of the electrical cables and then noticed that there is a metal bracket holding the fan body to the black upper vent body. I did not figure out how to disconnect this so I could pull the fan down out of the black vent. It has some weird small thread screw on one side and a plastic butterfly type screw on the other. I thought I may have read that you don't have to disconnect this, but I don't see how you pull the fan out otherwise. Unfortunately I had to put everything back together so I could get to work, so I didn't get a lot of time at that point to try and get the fan out. I appreciate any help on this.
    On this link you can see the metal bracket you can see the metal bracket on the right side connecting the fan body with the black upper vent body. Image: 2004-2009 Toyota Prius battery pack, second generation, size: 1024 x 682, type: gif, posted on: April 6, 2009, 6:44 pm - Green Car Reports
  2. JC91006
    16,496
    8,406
    you should disassemble all the vents as well. get a good cleaning while it's all opened up.
    btw, how did you get dog hair off the headliner and seat upholstery?
  3. elliptical22
    Eau Claire, WI
    even if I remove the top vent it will still be attached to the fan by the metal bracket. I need help with disconnecting that. I'm considering cutting the plastic push pin that connects it on one side to get in there. I could be overlooking something obvious here, I am not that mechanically inclined, that's why Im asking.
    I didn't get all of the dog hair yet, but got most of it. Fortunately there wasn't much on the headliner. Just repetitive vacuuming.
  4. Mendel Leisk
    38,893
    Is it possible to clean without complete removal, when it's exposed but still attached?
  5. elliptical22
    Eau Claire, WI
    http://priuschat.com/attachments/battery_blower-pdf.24329/
    In this document it states to remove the ventilator clips to remove the vent on top of the fan in order to remove the fan. When I was in there I didn't understand how to remove this black plastic piece (what looked like a push through clip). Anyone know how to remove this clip?
  6. JC91006
    16,496
    8,406
    You push the center of the clip in and it'll release it. Press with the tip of a phillips screw driver.
  7. elliptical22
    Eau Claire, WI
    Okay thank you, I will take another shot at it then.
  8. elliptical22
    Eau Claire, WI
    Alright so I got back in there and was able to remove the fan. I was surprised to see that the fan was hardly dirty. There was about a mm of dust cake on the blades. I cleaned a bunch of dog hair from the interior of the car when I bought it a few weeks ago, hmm. I bought it from the original owner, she didn't say anything about the it being cleaned before but when I was in there it looked as if the bottom vent had been accessed before. Anyway I'm glad it was clean and it appears I have a good battery, car has been running well so far. Thanks for the help.
  9. bisco
    49,725
    great start, all the best and welcome!(y)
