READY won't turn on, and general maintenance
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by liberate88, May 10, 2022.
  1. liberate88
    liberate88 New Member
    23
    Idaho
    This is a two part question.
    2007 Prius with 220,000 miles. Bought third hand (from a friend) in 2016 with 160,000 miles.
    The ready light doesn’t turn on, and in fact I haven’t seen any of the side dash lights come on besides the blinkers, car door, and seatbelt. No tire pressure check, or oil check. I always thought it was some inconsequential issue, but after reading threads I realize that the “ready” light should turn on. This has been going on for at least 20k miles without a problem running the car.
    I checked the 12v battery and it showed 11.9. I haven’t replaced it in the 60,000 miles I’ve had the car over the last 6 years. This winter got down to -15 regularly at night. Sometimes when I start the car the battery meter in the center console is very low. Now I just saw something about replacing the combination meter assembly?
    Maintenance.
    Last year my HV water pump went down. The air conditioning stopped working, as did cruise control, and the warning light came on in the center console. I got code P0A93. I had it replaced and after doing research realized that I was supposed to have changed the coolant in the inverter. I want to avoid this mistake again by making sure that I do all of the important maintenance. I used to take my car to a good shop, but not one that specialized in Prius. They treated me well but didn’t make any suggestions.
    Previous owner at 159,000 miles: changed spark plugs, serviced fuel injector
    181,000 miles: transmission fluid replaced? That’s what it reads with “Toyota WS Fluid”
    In the last 60,000 miles I’ve:
    -New tires
    -Breaks checked (likely to change one set this time)
    -Oil changes at regular intervals
    -Cabin and engine air filter multiple times
    -Headlights replaced
    What should I have done?
    -Transaxle fluid replaced? Or did that happen at 181k?
    -Differential?
    -12v battery - if so, do I need to get specific with the mechanic?
    -Break Flush?
    -Engine Coolant replaced?
    I live out west and take it on long hauls at least once a year (8-10 hours in one day). I also ride on dirt roads... anything specific for physical checks?
    THANK YOU!!!!!
  2. Aegean
    Aegean Active Member
    454
    203
    Alexandria VA
    At this point I would change both coolants, brake fluid, serpentine belt and clean the hybrid battery fan.
    There is no separate differential fluid as it is part of the transaxle. The WS transaxle fluid has been changed already. The 12v battery can be tested but no immediate need to change.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    IF the car runs ok AND the main dash display (aka speedo and fuel gauge) work ok, but not the side warning lights, I might think that someone had taken the cluster (CM) apart (to replace a bad capacitor) and possibly not put it back together correctly? I recall that there are two flex cables that have to be unplugged when removing the main board. Just a thought.
