Real world EV only mileage expectations
Discussion in 'Prime Main Forum (2017-2022)' started by schja01, Jun 12, 2018.
  1. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Hello,
    I should have my '18 Prime Advanced in about 10 days.
    What I've learned so far is dealers really are not well versed in the Prime.
    For that reason most of my knowledge so far has been from reading.
    I did take a few test drives but none were charged enough to even get into EV mode.
    I believe there needs to be at least some level of charge to enable EV mode.
    From the vehicle's display that level seems about 20%.
    I would Ideally like to run my prime in EV only mode as I put on very few miles each day.
    Certainly less than 25 per day.
    Question:
    Is Toyota's 25 mile EV mode based on the 80% above the 20% minimum for EV mode?
    Is 25 mile in EV mode only a realistic expectation?
    I'm a 71 year old (technically versed) Geezer, not a lead footed driver but I have no
    HiperMile expectations either.
    If I am expecting 25 EV miles per charge are my expectations unrealistic?
    Probably stop and go semi-suburban driving 45mph or less on average.
    Thanks,
    J
    farmecologist likes this.
  2. bill188
    bill188 Junior Member
    Aurora, Colorado. USA
    You should have no problem with the 25 Miles as long as there are no major hills.. Hills and highway miles kills the EV range .
    schja01 and jaqueh like this.
  3. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    25+ miles when it's warm out is easy to do, no hypermiling needed. It's better in town, but even I get close to 30 miles EV and most of my drive is rural highway. (though I do usually save my EV range for the slowest spots, and my commute is at least 75 miles a day, so definitely outside EV range)
    That stop and go 45mph is probably the sweet spot and you should get better EV range than I do.
    Now winter is going to be different, and maybe someone else here with a similar climate can tell you what they get. I bet with you drive, it would be close to 25 miles though. The heater is a much bigger drain on our power than A/C.
    You'll love it, I know I do!
    schja01 likes this.
  4. schja01
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Thanks.
    Certainly no hills. Maybe an bridge underpass or two from time to time.
    Highways 5% give or take.
    Basically I would like the feel of a 100% electric car eg. Leaf, Bolt but not ready to give
    up the security of a gasoline engine "just in case". Not looking for Tesla performance
    either.
    J
    heiwa and Bob Comer like this.
  5. schja01
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Winter shouldn't be too much of an issue. Our second car is a '13 Toyota Venza crossover. It has AWD just for winter driving. Once the roads are cleared I hope to use the Prius in winter. I know my '04 Prius was a little squirrely on slippery roads.
    J
  6. Bob Comer
    708
    460
    Yeah, This is my second Prius and I'd rather not drive it on really bad roads if I can help it. The car before my my first Prius was a Subaru, and I miss it every time it gets bad. (which is about 2 times every 3 or 4 years, I also like where I live. :)
    Nic Steussy likes this.
  7. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    I live in hilly west PA. My usual drive is highways about 60-65mph. I get probably 27 miles on electric during the summer. Wintertime here is difficult to keep the engine off if you use the heaters or it's cold enough out(20'F or so). It's probably more like 20 miles on electric in the winter time, realistically.
    The flatter road, warmer temperature, and slower you go, the better your electric range will be.
    schja01 likes this.
  8. citiprius
    citiprius Active Member
    241
    238
    51
    2018 Prius Prime
    I've got average 35 mile per charge mostly on local roads until EV mode is disabled, which is around 20% battery capacity left? When you test drive, if the battery is low, you can hold the EV button till the display shows "Charge Mode", that way you can drive until the battery is charge enough to have EV mode enabled for your test drive. Or next time call ahead and have the sales rep fully charge that for you. I have the same experience, the sale reps are not prepared, they don't charge the vehicle before you test drive. You have to explicitly ask them
    schja01 likes this.
  9. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Yap, it's very realistic. You can easily go over 30 miles in warm season. Only problem you may encounter in your local is during dead of winter with sub zero weather, you may get less than 25 miles. Still overall average throughout year would be above 25 miles in my experience during last 11 months.
    #9 Salamander_King, Jun 12, 2018
    schja01 likes this.
  10. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    I have a Scangauge 2 attached to my '17 Prime. My battery charge will be about 14% when EV mode shuts off. It will then get fluctuate between 12-15% driving it in Hybrid mode. Fully charged is only 82%. It uses some algorithm to conserve future battery usability. If you are only doing in town at low MPH and minimal hills, then you will probably get great miles per kW. I commute 45 miles mainly interstate. I get about 25 miles on all electric. I usually use EV-Auto and let the computer decide when to use EV/Hybrid mode. It kicks in the ICE on larger hills.
  11. bisco
    52,405
    the engine may also start in winter.
    Dudley1030 likes this.
  12. prius4owner
    prius4owner Member
    84
    30
    Southern California
    In southern California, I am easily getting 30+ miles per charge.
  13. EazyPeazy
    EazyPeazy Member
    110
    83
    New York
    I’ve had my Prime Advanced since the end of April. Have around 3800 miles. I have a hilly local commute to the office, but have been able to achieve about 36.5 miles max a couple times. Usually in this warm climate in NY state now (finally), it’s between 32-35 miles. Waiting for the winter later to see how much the range decreases. Probably a 30-35% decrease depending on whether heater is turned in. For me A/C drains barely any battery. Our cars are super efficient that way. It’s amazing how carefully I Drive now trying to extend EV range as long as possible. I’ve added at least another 5-10 min on my trips to the office now. Lol.
  14. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    You will easily exceed that 25-mile rating.
    There are a variety of videos on my YouTube channel showing various real-world drives. Here's a recent one with a mix of suburb & highway driving, as round-trip as possible to show how effortless it was to drive the EV distance...
  15. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    Around 25 miles during winter/summer and 30+ miles when no AC/heating required.
  16. Mark57
    2,945
    2,740
    OK
    This is from yesterday morning. 35.7 miles estimated and I drove 39.9 actual EV miles. 84° at 6am, Yeah, it's been hot.
    Nic Steussy, heiwa and benagi like this.
  17. schja01
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    What is producing the graphic to the right of the MID in the video?
  18. john1701a
    12,833
    5,310
    58
    It is an Android app called "Hybrid Assistant".
    I just connect my phone with a Bluetooth reader and hit record.
    schja01 likes this.
  19. schja01
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Thanks.
    I'm an iPhone guy so I guess I'm out of luck.
    J
  20. juhjuhjuhjames
    juhjuhjuhjames Junior Member
    49
    seattle
    I have a 16 mile round trip commute that sounds similar to yours. About 5 miles is freeway but there’s always some sort of traffic, so I average right around 45mph then 60 for maybe 1 or 2 miles of that drive. Going to work is downhill and going home is uphill in the suburban areas. I haven’t had to use AC yet (had the car for a month) and my ev range has consistently been around 27-30 miles.
    Edit: might also be worth to mention that I have a heavy foot, and I could probably improve my ev range even further if I tried to drive more effeciently
    schja01 and bisco like this.
