Realibrating ECU for different tire size Revolutions Per Mile??
Discussion in 'Gen 2 Prius Technical Discussion' started by KK6PD, Sep 10, 2010.
  1. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    OK kids, here's todays question..
    Has anybody, after dumping the Goodyear Integrity tire which has a Tire RPM of 855 for other tires, lets say a Michelen Fuel Saver AS, which has a RPM of 851 for the 185/60 R15, or the 195/65 R15 which has a RPM rating of 832 or any other tire for that matter, had the Dealer RECALIBATE the cars ECU to accept the different tire RPM value?
    I called two different dealers here in SoCal, and both said can't be done, although both were surprised that I understood the RPM concept, and how it relates to computed MPG, and even thought enough to ask the question!
    Anybody else gven this some thought?
    Anybody, thoughts, opinions, waddya know????
  2. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    My OEM integrities read 2 to 3MPH high at 65 MPH. I put on 205/60/15 Michelin Primacy MX4 and the speed is now right on the money. The MPG was unchanged. Actual MPG might then be a few % higher, since car was originally going slower then indicated (fewer miles). Recalibration is probably not practical, if at all possible.
  3. KK6PD
    4,003
    944
    118
    Yeah, that makes sense, the RPM for your tire is 844, I figure if you input a specific value for the Goodyear tire, why can't you change it for some thing different???
  4. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    We either need a co-operative leak from Toyota or someone needs to reverse engineer the computer that makes the calculations and figure out which value to change.
    Then we need someone who can go into the Prius software and make the desired change. There have been other cars with enough info out to do that, but I don't expect it to happen soon for Toyota.
  5. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    It wouldn't be released as it would allow -more- dishonest behavior (some would change it so the car would show lower mileage over time).
  6. vertex
    670
    143
    new york
    2018 Prius Prime
    OK Pat, your a clever guy. Design a circuit to intercept the speed sensor and put out a signal that is X times the input signal. Now you can "calibrate" your spedometer to whatever you require.
  7. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    If it's that simple, you can buy one of these
    Official home page of the Yellow Box Speedo Recalibrator
    Unfortunately, there is a good possibility that the speedometer uses all 4 speed sensors (one per wheel) and sends a composite signal to the speedometer. Maybe someone here knows for sure?
    On my Gen 3, the Odometer is just about spot on, within 1%. Also, my ScangaugeII shows actual speed, while the speedometer reads 1-2 mph high at highway speeds. That means that if I did use a Yellr Box type device to correct my speedometer, the odometer would then be off as far as the speedometer was off before I corrected it.
    Since the game with Prii is tracking MPG, I would rather have a spot on odometer than a spot on speedometer. My Prius speedometer is within 2 mph at any quasi-legal speed.
  8. vertex
    670
    143
    new york
    2018 Prius Prime
    Cool, just what I had in mind. Yes, you will need 4 of them. The ABS pickups appear to be the only speed sensors. The cost would be nearly $500. Seems easier just to buy good tires that give the correct speed. There seem to be enough options.
  9. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Considering that and my desire to have the odometer remain accurate, I will learn to mentally subtract one mph at normal highway speeds.:cheer2:
    If I want to see the correct speed I can select speed as one of my ScangaugeII readouts. Or turn on a GPS.
  10. KK6PD
    4,003
    944
    118
    I remember back when you simply needed to change a gear in the transmission and you were close.
    Now he car needs accurate RPM info... I give up
    I am staying with the Michelin Fuel Saver 185/65 R15 size at 851 RPM's, close enough to 855 for me!!!
  11. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    More than close enough:cool: when you consider that the 1/4 inch of rubber that is there to be worn off the tire tread reduces the tire radius by about 2% so causes your speedometer & odometer to read 2% higher than they did when the tires were new.
    A stock 855 would be about 872 revs miles when the tire was worn enough to need replacing.:cheer2:
  12. vertex
    670
    143
    new york
    2018 Prius Prime
    Good plan!
  13. bwilson4web
    15,524
    I use a Garmin nuvi as a GPS speedometer:
    I also use the accumulated distance to correct the distance when I enter my data into the MyHybridCar.com database:
    2003 Toyota Prius - Hybrid Fuel Economy Data - NHW11 2003
    Now that cooler weather is returning, I can conduct 'standard day' mileage tests to compare:
    • 195/70R14 - currently front tire
    • 175/70R14 - currently rear tire
    However, there is one thing I can tell where the 195/70R14 goes where smaller tires can not follow, up to 40-43 mph with 'hybrid mode.' That means I can travel at traffic speeds on 40 mph posted streets, keeping up with traffic, and the ICE will shutdown when it can. With smaller diameter tires, we meet and exceed the 42 mph threshold and the ICE runs even if not needed (aka., descending a grade with traffic.)
    My preliminary data suggests the tire drag is not a significant function of tire diameter but the ability to travel a little faster with the ICE off helps in an urban, per-tank, basis.
  14. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    Has there been any more headway in this area of questioning? Does the small percentage of difference in the tires size as Ken mentions below fall within the percentage of allowed error? Or is there a chance the touring ECU is programmed differently?
    ______________Touring__________Base
    size__________195/55R16______185/65R15
    sidewall height__107.25mm______120.25mm
    inner diameter___406.4mm_______381.0mm
    overall diameter__620.9mm_______621.5mm
    circumference__1950.61mm______1952.5mm
    ride height_____310.45mm______310.45mm
    Just wanting to know for those including myself that may make any changes to the tire size...could effect correct odometer reading, mpg...ect.
  15. KK6PD
    4,003
    944
    118
    I just said screw it and bought the Energy Savers in the 185 size. They work just fine!
  16. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    This is not the kind of response i was hopping for.... Nothing in Torque to make adjustments..or the sort?
    Don't think they make LRR or Energy Saver tires in 215/35/19... :Rollin'OnRubberBands:...
  17. KK6PD
    4,003
    944
    118
    One of the points that was mentioned, I thought a valid one, is that if you could change the value, you could conceivably commit fraud by miss setting the actual miles! Ya big deal, that's what I said. apparently some states actually have laws on this. Those places are no fun!!!
    For something I thought would be so easy, it's just not!
