Really need to buy alloys...what's compatible?
Discussion in 'Prius c Main Forum' started by Absolutely_Red, Nov 6, 2019.
  1. Absolutely_Red
    56
    36
    Virginia
    2016 Prius c
    On Sunday, I hit the mother of all potholes in Illinois and bent the steel rim (OEM). I'm ready to put some alloys on this car. When I look online, it tells me that 2016 Yaris alloys are NOT compatible with the 2016 Prius C. Is that right?
    I'd be grateful for any guidance. I'll be buying new alloys soon, and want to get the right size .
    BTW, are all tire pressure monitoring valves the same size? Do I need to worry about the whole for that?
    Thanks.
    Just sign me,
    Worried Widowed Writer in the [Mid]West...
  2. Leadfoot J. McCoalroller
    8,037
    7,518
    Pennsylvania
    2018 Prius c
    “online” is a broad term.
    Can you make a finer attribution for that data point?
  3. Absolutely_Red
    56
    36
    Virginia
    2016 Prius c
  4. Absolutely_Red
    56
    36
    Virginia
    2016 Prius c
  5. Leadfoot J. McCoalroller
    8,037
    7,518
    Pennsylvania
    2018 Prius c
    There are a few wheel sizes that fit. For now let’s restrict it to the ones that can work with the tires you already own, so that would be 15x5 and 15x6.
    You need a 4x100mm bolt pattern, and you want alloys, and you want a set of 4 under $500 and vaguely “Toyota-ish."
    The briefest of searches gave me this.
    I’ve never heard of that company, can’t vouch for them at all… just pointing out that these shouldn’t be too hard to find.
    I don’t believe that the photo used is actually that of one in your size- it’s showing a wider aspect and a different bolt pattern. However, if the shape and finish are good for you, it ought to work fine.
    I believe those will fit and work fine.
    #6 Leadfoot J. McCoalroller, Nov 6, 2019
  6. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I see no reason the Yaris wheels would not fit, they are not much cheaper than the new wheels I linked.
    Used on ebay 378 + 58.50 shipping to you = $436.50
    New on tirerack = 437.36 + 23.18 tax to you = 460.54
    You may or may not be able to move the TPMS sensors between wheels, I am no expert on that.
