rear 12v tap location?
Discussion in 'Prime Audio, Electronics, and Infotainment' started by 17primesilver, Feb 19, 2018.
  1. 17primesilver
    17primesilver Junior Member
    17
    San Jose
    Anyone know where would be a good tap location in the rear, I found some exposed wiring under the rear seat, but its still a pain to tap. I don't know how to get to the rest and don't want to break any fasteners.
    amp requirement is minimal, for some el wiring only. Preferably power on start, not accessory.
  2. Tideland Prius
    16,616
    Isn't there already 12V outlet in the rear seating area?
    Ohh, you want it on start, not accessory. Umm..... not sure. Power windows? What else in the rear has power only on IG-ON/Ready?
  3. Diemaster
    Diemaster Active Member
    295
    262
    so. cal
    might be a bit risky but my first thought is the contractors for the battery pack.
  4. mercat68
    mercat68 Active Member
    311
    216
    Mount Airy, MD
    Just curious: As a practical matter, why does it make a difference if it's only ignition-on vs. accessory?
  5. Elektroingenieur
    2,515
    3,287
    Three Touring
    I don’t recommend tapping wires, but if you’re looking for information about the wire harnesses, see the Electrical Wiring Diagram (available by subscription to techinfo.toyota.com) under Location & Routing > Body > Position of Parts.
    Redthorne likes this.
