Rear air conditioning
Discussion in 'Gen 2 Prius Main Forum' started by gordoj52, Aug 3, 2010.
  1. gordoj52
    gordoj52 New Member
    Hainesville, IL
    I did a search on this and couldn't find any information, but is there rear air conditioning in a GEN II prius or does it solely rely on the front ac
  2. shazam1
    shazam1 New Member
    No rear AC, only front. I own a 2010 Prius IV and has no rear AC either. Gotta say it's pretty powerful AC tough. Folks in the back will feel it no problem. Not sure if the Prius V does have rear vents.
    I looked at that before I bought because the Camry I traded in had rear AC, but don't miss it much since the Prius AC works pretty well and has the plasmacluster technology.
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    my genII has never given me problems. you're correct to assume there is no rear vents.
    anytime i've ever asked guest in the back... i always get a " i can feel it.. it feels good back here"... comment.
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    No rear air conditioning ducts/vents in the Gen II rear seats/hatch area.
    Point to remember: The HV battery operates best at temps that
    humans like, lets say 50-80 degF. (So, it makes no sense to go totally
    without heat in the winter or air conditioning in the sumer.) It gets it's
    cooling air via the vent on the passenger side of the rear seat. This
    vent should never be blocked.
    Usually, air from the passenger cabin is gently flows through the HV
    battery by a slight over-pressure in the cabin. If the battery gets too
    hot there is a rather loud fan that forces air through the battery. HV
    battery exhaust is through a vent just behind the passenger side rear
    wheel and hidden under the outer body work. There is a similar vent
    for the cabin on the driver's side.
  5. David Beale
    David Beale Senior Member
    5,963
    1,982
    Edmonton Alberta
    There -are- rear A/C vents in the Prius. They are under the front seats. They are not controllable. So don't place objects under the seats as they will block the vents.
    The above posters are correct though. There is no separate A/C system for the rear passengers.
    Rangana likes this.
  6. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Those vents under the seats provide heat. If you have your system set on "AUTO" and the system is cooling it does not route airflow to the floor, which is when those vents would circulate air. You can manually set airflow to the floor and it will come out those vents...but they are meant to be for heat where the system will route airflow to the floor.
    So no, no A/C vents in the rear.
