Rear alignment on 2nd gen Prius
Discussion in 'Newbie Forum' started by Emotionm, Jun 20, 2019.
  1. Emotionm
    Emotionm Junior Member
    Los Angeles
    Hi all!
    I recently did a wheel alignment on my 08 Prius after replacing rear struts. My repair shop corrected front, but did nothing on the rear, since they didn’t have shims available.
    They also told me that they will charge extra for that work. I didn’t ask how much.
    My right rear toe is 0.31.
    Pls. See pics attached.
    What’s your opinion? Should this be corrected or I can leave as it is?
  2. PriusCamper
    PriusCamper Senior Member
    11,190
    4,560
    Pacific Northwest, USA
    Looking forward to what others have to say about this... Do you have signs of uneven tire wear already? Or just trying to get better numbers to prevent that?
    49,694
    welcome!
    most people ignore it, as does toyota. it depends on how ocd you are :p
    PriusCamper likes this.
  4. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    How do you adjust it with shims? At least you know how far it’s off. That should help to know what size shim to use
