Rear brake cylinder
Discussion in 'Gen 2 Prius Main Forum' started by Ernie stires, Jun 13, 2023.
  1. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    Drivers side wheel cylinder hyper-extended again, happened before about 8 months ago. In both cases it seems that braking while in reverse may be the cause. Not sure why this would happen, all hardware is correct. Ideas?
  2. mr_guy_mann
    mr_guy_mann Senior Member
    3,483
    1,587
    NJ-USA
    What do you mean - "hyperextended"? Pictures of the results?
    Ernie stires likes this.
  3. ChapmanF
    15,705
    I don't think that happens when all hardware is correct, so it would spur me to carefully recheck assumptions.
    One thing that can easily happen is adjusters get swapped left for right (or just one gets replaced, and isn't for the correct side). They look almost identical, but the thread directions are different. Any one that's not on the correct side of the car will auto-loosen instead of auto-adjusting.
    Ernie stires and Tombukt2 like this.
  4. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    The piston (one side) was pushed right out of the cylinder.
