rear brake grinding noise at low speed
Discussion in 'Prime Main Forum (2017-2022)' started by MarkOlin, Mar 29, 2020.
  1. MarkOlin
    MarkOlin Member
    77
    37
    Buffalo, NY
    2020 Prius Prime
    My car has about 2000 miles on it. From day one I get a grinding noise from the rear brakes at speeds of 1 to 3 mph. Originally I thought the car might have some surface rust on the rotors but I get this noise all the time, even after a long commute.
    Is this normal?
    Thanks
    Rosanne Shalf likes this.
    49,397
    not that i have read, have you returned to the dealer? maybe a dragging pad or e brake is not releasing all the way.
    or it might just be something in there rubbing.
    scona and Mendel Leisk like this.
  3. ChapmanF
    15,481
    Just to be clear, is the noise only there when you are braking?
  4. MarkOlin
    MarkOlin Member
    77
    37
    Buffalo, NY
    2020 Prius Prime
    yes, only when braking and only at very low speed
  5. Rob43
    Rob43 Senior Member
    1,373
    1,047
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    I won't go as far as recommending a full "bedding your brakes in", but would suggest one medium/hard 50 mph to 2 mph braking event.
    Then let everything cool down, maybe your issue goes away.
    Rob43
    FuelMiser likes this.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Since it is new and still under warranty, I would strongly suggest taking in to the dealer to have it checked out.
    Before you go, practice demonstrating the noise.
    Not sure it would be a good idea to make any "hard stops" if there might be something wrong back there.
    davecook89t and Mendel Leisk like this.
  7. bisco
    49,397
    no reply
  8. Rosanne Shalf
    Rosanne Shalf Junior Member
    Ashland, Virginia 23005
    2019 Prius Prime
    Same here. As long as it doesn't indicate a problem, I am not worried about it.
  9. PianoBench
    PianoBench Member
    145
    91
    San Francisco
    Generally if you are not experiencing vibration, the vehicle pulling to one side, or any unsafe abnormal vehicle behavior while under braking, I would not be concerned. The noise is occurring because there is rubbing somewhere between the brake pad and brake caliper system that holds the brake pads in place. When you are braking, there are shims and anti rattle clips between the brake pads themselves and the brake caliper that try to hold the brake pads steady and firm when under braking. Those skims and anti rattle clips just need to have some brake anti-seize applied to them. Pretty much lubricant for where those clips will come into contact with the brake pads and caliper.
    NOTE: YOU DO NOT PUT LUBRICANT BETWEEN THE BRAKE PADS AND ROTORS.
    Here is a good diagram that can help you understand what is going on.
    https://www.aa1car.com/library/disc_brake_floating_caliper_assembly.jpg
    Here is a good video on how to fix this problem yourself if it really bothers you.
    Edit: Its a 15 minute video. To jump to the most likely noise for your case, he starts around the 9 minute mark. Because your vehicle is new, it is most likely rubbing on parts that hold the brake pad in place that need to move as you depress the brake pedals.
    #9 PianoBench, May 11, 2020
