Rear brake replacement on 04 Prius? Can I do it myself?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jason H, Aug 12, 2017.
  1. Jason H
    Jason H New Member
    Lehigh Valley PA
    Hello everyone! I recently inherited an 04 Prius from my dad with 294k miles. It's still running great and has never had a major repair needed.
    However, when I took it in to get an oil change/tire rotation, the rear brakes were measured at 5/32. Seems strange because the rotors were resurfaced and the rear brakes were done in Dec 2016.
    So I need to do a little investigating tomorrow, i.e. take the wheel off and measure for myself. In the meantime I am trying to find replacement pads/rotors online to purchase (if needed) and I cannot find rear brake pads for the life of me.
    Is this a repair I should be doing myself? I found this video -
    - It seems no different than most of the other cars I've done brake pads on.
    Where can I find the parts? Help!
    Thanks!
  2. JC91006
    16,674
    8,519
    Don't believe anything the oil change people tell you, it's all a way for you to spend money with them. You should have a trusted mechanic do this type of work, not hungry oil change people that want your money
  3. Patrick Wong
    18,200
    6,493
    A 2004 Prius in North America has rear brake drums and shoes. That is why you cannot find pads. Also new shoes have a thickness of 4 mm and the minimum is 1 mm.
    4 mm = 0.16 inch
    5/32" = 0.16 inch
    So I don't see a problem here.
  4. Jason H
    Jason H New Member
    Lehigh Valley PA
    This is my trusted mechanic. They didn't say I should have my brakes checked/replaced, I just noticed on the report they gave me afterwards that it showed 5/32. As a new owner, I was unaware that my car actually has drum and shoes. Thanks to the other member who replied, I now understand and know I don't have a problem.
  5. Jason H
    Jason H New Member
    Lehigh Valley PA
    This is great news! Thank you very much!
  6. makbg1
    makbg1 Junior Member
    35
    LA
    I can say rockauto.com has a decent quality or carquest.com . I have purchased from both breaks for my cars and other parts as well.
