rear brake service
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Nelson Hogg, Jan 18, 2014.
  1. Nelson Hogg
    Nelson Hogg Junior Member
    I have a 2012 prius v with just over 15,000miles. The dealer tells me the rear brakes are worn to the point that both rotors and pads need replacement. The front brakes are fine. Does this sound normal? My VW Passat went much farther in similar driving before needing this. And, the thought of having to spent $700 or so every 15,000 miles does not make me happy about the future with this car.
  2. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    This is not normal and hard to believe. Make them show you, and if you do not know what you are looking at, go see someone else who does.
  3. vskid3
    vskid3 Active Member
    773
    228
    Unless you brake like a madman, its very unlikely you'd wear out the brakes this fast on any car. Also $700 seems really high for just the rear brakes.
  4. frodoz737
    4,297
    2,348
    33
    A model 2012 with +15,000 miles...something is wrong with the car or the service department. Get a second opinion please.
  5. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Only if the parking brake has been dragging. I'd consider this either a warranty issue or a downright crooked dealer. Rear brakes could easily last 150,000 miles or more. Take it to a brake specialty shop and see what they say, or to a different dealer.
    Normally you expect to wear out 2 sets of front brakes for 1 set of rear, maybe 3.
  6. Mendel Leisk
    38,742
    I can't see a dealership service department willfully falsely reporting the status of specific brakes. Look into the low hanging fruit: dragging parking brake, seized caliper pins.
    What's your location? Salted roads might be a factor.
    And just to dispel the mystery, if you're able: jack up at least one rear corner, or the complete rear, and remove one wheel for a look yourself.
  7. frodoz737
    4,297
    2,348
    33
    Pads are not covered under the basic 3/36 warranty, but with this few miles it can not be attributed to "normal wear". Either way, my recommendations stands to get confirmation the work is required, and if it is, why.
  8. Air_Boss
    Air_Boss Senior Member
    3,953
    1,085
    New Yawk
    Very unusual, Prius or not.
  9. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    I'll add that with the sort of drag required to wear the brakes in 15K miles, the OP should also be seeing some pretty poor gas mileage.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    If the car has been in constant use then it is extremely unlikely that the brakes need replacement, however if it had been stood on a dealers forecourt for a while then the rotors could have rusted, leading to premature wear of the pads. Do the rotors look shiny ?
  11. New2Priusv
    New2Priusv Junior Member
    32
    Toronto, Ontario
    I must say that this sounds improbable when the majority of Prius owners often do not need the brakes service for 100,000 miles or more (or so I have heard). I hope the tales of costly brake service are few and far between, because that's one of the many reasons I bought one - the maintenance savings!
  12. Mendel Leisk
    38,742
    One of the best ways to avoid a costly brake rebuild is by periodic "service", ie: removing the wheel, removing caliper mounting bolts, ensuring the calipers pins are not seizing, pad wear is even, disk is wearing evenly and not warping. A cursory inspection yearly, and more in-depty inspection bi-yearly, is in the schedule I believe.
  13. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    This is just another one-post troll.
  14. New2Priusv
    32
    Toronto, Ontario
    For sure - I should have been more clear in my post. I know that inspections, etc. still need to be done and are on the schedule, but I just meant that the number of incidents of brake repair/replacement (especially say, within the first 5 years or so) should be far less with a Prius compared to conventional vehicles.
  15. krissl
    krissl Junior Member
    Never put brakes on my 2005 Prius with 227,000 miles on it. Do a lot of interstate driving. Hybrid battery now needs replaced. Can't deal with the flying bridge on the current Prius. Looking at a new Prius V
