Rear brake squeaking
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by brick, Jan 4, 2010.
  1. brick
    brick Active Member
    1,083
    79
    Upstate NY
    What's the most likely cause of a god-awful, nails-on-a-chalkboard squeak squeak squeak squeak squeak noise coming from a rear brake? It's most pronounced under light braking (which is odd...pre-pressurization of brakes during regen?) and goes away when I put it in neutral and rely on the friction brakes for a harder stop.
    I did try to make a few moderate stops in N to clear off any corrosion...no dice. I just noticed it for the first time this evening. In lieu of an idea, is it particularly difficult to yank off the drum and have a look? (All of my prior cars had discs on all four wheels...fancy that.)
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    The brake could need adjustment. The rear drum brakes are self adjusting, but sometimes they need a little help.
    Tom
  3. Patrick Wong
    18,210
    6,513
    After you remove the tire and release the parking brake, you should be able to pull off the drum with your hands, for a look. In the event that the drum is stuck, insert a couple of 6 mm bolts into the two threaded holes in the drum, to force the drum off.
    Might want to have a can of brake parts cleaner handy, so that you can clean off the brake shoes and drum.
    2 people like this.
  4. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Thanks, guys. I picked up some brake cleaner and I'll get in there this weekend if the issue persists. (May as well since I have to rotate the tires, anyway.) In the mean time I happened across Hobbit's brake adjuster write-up, which has proven very useful! Based on his description I figured it might be possible that I just haven't been braking hard enough to actuate the adjusters, perhaps due in part to some corrosion or grime that resulted from my northern holiday adventure. So I did the following before leaving work:
    1) Power up the car.
    2) While still parked, push the brake pedal all the way to the floor and leave it there until the booster pump quits buzzing.
    3) Release and fully re-apply the brake pedal several times before driving off.
    The squeaking is much better than it was yesterday or this morning! It's less obtrusive and doesn't really happen unless I'm decelerating below the 8mph transition speed. So that's progress.
  5. brick
    brick Active Member
    1,083
    79
    Upstate NY
    I finally had a chance to fix it today. I had tried and failed previously because I couldn't get the drums off so this time I went at it with a pair of 8mm x 1.25 bolts to pull them off. After that it was easy. Both sides looked good in terms of wear and the adjusters still looked well-greased. The pads and drums looked a little glazed so I used some 80 grit sand paper per galaxee's instructions followed by a good cleaning. I also advanced both adjusters a few clicks to get them just to the verge of contact with the drum.
    The result? No more noise! And I learned a new trick which is always fun. :)
  6. qbee42
    18,058
    3,079
    Northern Michigan
    Cool. Good work.
    Tom
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Reviving this older thread to see if you guys think my issue is the same as Brick's or something different.
    About 2 weeks ago I was braking from ~70mph on a rather steep downhill highway to stop for a turn. At around 15-20mph (maybe slightly higher--wasn't looking) I had a similar high pitched steady loud squealing from the left rear wheel area.
    AFAIK I was still in regen, but it may well have transitioned to friction braking as it was fairly aggressive braking from such a high speed. My first thought was that it was the wear pads telling me my brakes are worn and needing replacement. I decided to test it out and immediately sped up to around 40mph, put the car in Neutral and applied the brakes--no squeal...hmmm.
    A week later I had had no recurrances until I again was making the same exact hill/stop/turn and it squealed at the exact same location!
    Since that time I've heard it very briefly squeal at a couple other locations and am yet to be able to say with certainty whether it's during regen or friction (obviously I suspect friction) braking.
    I was told, 10k miles ago, that my brakes looked good with a gross visual inspection by the guy who change my tires, but they did not do formal measurement or inspection (despite my asking them to), so it's possible they didn't do anything at all.
    I could pull the wheel and look myself, I guess, but 1)I'm lazy, and 2)I'm not exactly sure what I'm looking for, though I think I'd recognize a worn through brake pad when I saw it.
  8. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Hey, I had forgotten all about this! (Isn't digging through your old posts weird?) Your description of the noise sounds a lot like what I remember. Inspecting the rear brakes is really easy **if** you have the pair of bolts to free the drum. You can't see anything useful otherwise. What you need to do is insert the bolts into a couple of threaded holes on the drum, which press against the hub as you turn them and free the drum. Trying to pull by hand is an exercise in futility if the drums have been on for any length of time. Trust me, I tried.
    Read Hobbit's write up before you try. IIRC you need to de-energize the brake system before attempting this because otherwise there is a risk of the system pressurizing when the drum isn't there to restrain the shoes, which is probably bad.
  9. efusco
    19,891
    1,196
    Nixa, MO
    Thanks, guess I need to manufacture a little time to do this. Haven't heard the squeak since trying the accumulator reset trick...not sure if it's coincidental or if it fixed it.
    ? HD
