Rear bumper gap
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by torparts, Sep 5, 2015.
  1. torparts
    torparts Senior Member
    417
    643
    Compton
    I heard this known problem... Any fixes besides toyota ignoring the problem!
    52,403
    nope.:(
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    There are supposed to be "stronger" clips available for holding it on. You could ask about that (at the dealer).
  4. torparts
    417
    643
    Compton
    thank you !
  5. StarCaller
    StarCaller Senior Member
    1,280
    732
    Cedar Crest, NM, USA
    neone has a part number for the new clips?
    this friggin bumper gap annoys me every time I walk to my car....//
  6. daddyd302
    daddyd302 Junior Member
    48
    West Allis, Wisconsin
    What does this gap look like?
  7. Mendel Leisk
    41,925
    Ours goes from zip at the wheel well to a bit more than 1/8" at the rear corner. Just an irritant, but it's hanging in there, I think.
  8. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    I used rubber to go under bumper wrap clip closest to hatch and then put a piece on upper end of both screw/spacer holes on rear of bumper wrap as i held it up and then snugged the screw in as to not strip plastic. Seems to have improved some.
  9. Steven Kopacz
    Steven Kopacz Junior Member
    Los Angeles
    I fixed my bumper gap on both sides of my 2012 with a part I found at Home Depot
    Everbilt Clear Bumpers 1/2” x 1”
    Both sides of my bumper where hanging off because the clips weren’t “locking” in.
    Removed the 1 screw from in the wheel well (right in plain sight) then pull back the bumper so I could see where it’s supposed to connect.
    To fix I cut each clear bumper in half (long ways) otherwise the bumpers push the actual bumper out. I put them where the clips need the extra “push” up. Used a flathead screw driver to secure the sticky side down and then popped the bumper back on. There bumpers are soft enough to budge a little which is why how thick they are works perfectly.
    C80151CE-2D5E-4825-8CF1-6707CE461EF2.jpeg 0716B86C-1F71-45B4-9BC3-6D31AB084B92.jpeg 54F3426A-A2DA-4D6D-9775-39409A755145.jpeg 4D06079B-C4CA-443D-AD96-1E407EF327F8.jpeg 9576B1BA-B38C-4CD9-B963-99D580D5AF75.jpeg
