Rear Bumper protector pad.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by triumph1, May 2, 2008.
  1. triumph1
    triumph1 Member
    275
    I was thinking about getting one, and recently I was rear ended and the body shop botched the install on the clear appliqué bumper protector the car comes with. I'm supposed to go back next week for the clear appliquéinstall. Is it best to just leave the clear appliqué off if I'm going to put on the pad?
    PriusChat Shop : Toyota Prius OEM Rear Bumper Protector [00016-47015] - $36.99
    Also, in the event I get rear ended again, will I be able to reapply the pad, or is it one and done install?
  2. patsparks
    10,664
    567
    Adelaide South Australia
    Leave off the clear applique just use the bumper protector. It will look odd having a sticker under it or you won't see it at all under the black protector. Resell the Prius applique as it is worth more than the black protector.
    If you are rear ended again and the bumper protector isn't damaged it should be removable and with new double sided tape re-install it. It just has 2 strips of double sided tape to hold it on.
  3. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    I just installed the hard rubberized rear bumper protector yesterday. It couldnt have been easier and it looks great. It would cover a great deal of imperfections on the bumper surface.
    I got it from the Prius Shop here!
  4. wchardin
    wchardin Senior Member
    2,055
    Nashville, TN
    Would anyone here recommend the Rear Bumper Applique? I have read the one review from the store and the guy didn't like it.
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I bought the applique before learning of the rubber strip. Next time I'm getting the rubber strip. Since I don't carry cargo often the applique is adequate.
  6. KayakerNC
    KayakerNC Member
    399
    Eastern North Carolina
    Use the vinyl rear bumper protector. When purchased as an option with the vehicle, this item (BP30) costs $129, compared with under $40 when you do it yourself. It's easy and looks good.
  7. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    Besides being more protective and cheaper, I think the black bumper protector looks better than the not so clear applique.
  8. chrisspaulding
    chrisspaulding sexy, high tech, fun
    556
    24
    Kentucky
    NO. Remove the clear appliqué before adding the black plastic protector
    YES. It's only double sided tape holding it on.
    p.s. Before any adhesive installs (like the black rear bumper protector) clean the surface first with denatured alcohol(store paint department) to ensure all oils/waxes/etc. are removed. This will promote best adhesion (imo)
  9. Speedwing
    Speedwing Junior Member
    48
    Southeast PA
    I recently installed the "clear" full length applique protector. You hardley notice it is there. For our use it works great. It was not difficult to apply .... but I have experience with doing this. The black rubber heavy duty is much easier to apply. My friends Prius is pretty scratched up from loading in his dog. I might buy him the black one for his birthday and install it for him.
  10. VenicePrius
    VenicePrius Junior Member
    Venice, CA
    I got the black, rear bumper pad on eBay for $30 + shipping - fits, looks, and protects great. Do it.
  11. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Dare to be different, that's me.
    Here are three photos of the clearshield covering the curved upper portion of the rear bumper shelf, specifically the upper left and upper right slope and everything in between. The shield stops right at the bumper shelf edge, it does not fold over the edge.
    Can you spot the clearshield?
    (the 3rd picture shows both the clearshield line and the bumper edge, you can see the edge, but the clearshield is very elusive)
    I vote for the clearshield.
    ZC1
