rear bumper protector?
Discussion in 'Gen 2 Prius Main Forum' started by smtrader, Mar 9, 2005.
  1. smtrader
    smtrader Member
    105
    Cerritos, CA
    Has anyone put on a rear bumper protector? Is it a hard plastic piece OR is it a clear soft piece?
    I just bought one on ebay and it came as a clear soft piece, but I was expecting the hard plastic. Any thoughts?? :roll:
    Thanks...
  2. LoreePrius
    LoreePrius Junior Member
    64
    The rear bumper protector came with the car. Part of the dealer package. But it's a one piece clear with a faint design then a outline spelling out `PRIUS'. I forget what the design is.
  3. KTPhil
    KTPhil Active Member
    1,379
    Some (like me) are considering a black rubber piece made for other models, which has been used by a couple of posters with good results.
  4. smtrader
    smtrader Member
    105
    Cerritos, CA
    Ok...that explains the variation I've seen! Sounds like the original Prius part is the clear soft piece, but others have improvised with the black hard piece!
    I now have both pieces and trying to decide which to return and which to put on my car. Any more advice about either piece please??
  5. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(smtrader\";p=\"70923)</div>
    I have had both and took off the thin clear one and replaced it with the black one from the Matrix. It really offers a lot more protection and looks good on my Salsa Prius.
  6. bobc
    bobc New Member
    361
    Durham, NH
    Ditto what SeaSalsa said...
  7. KTPhil
    1,379
    How did you attach the thick black one? Is it with adhesive, clips (any drilling?), duct tape?
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    <div class='quotetop'>QUOTE(KTPhil\";p=\"70953)</div>
    An adhesive...it is very easy to install
  9. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    I wish I had put the bumper protector on my Prius. The rear bumper cover now has a nice collection of scratches on it.
  10. KTPhil
    1,379
    Which one has the "lip" that covers the corner of the bumper? That point will take most of the abuse (for example, setting and sliding a heavu object into/out of the back)? I've seen two types. I'm hoping for a Toyota part, so any replacement will be easy to find later.
  11. bobc
    bobc New Member
    361
    Durham, NH
    KTPhil,
    Ugh, I've gotta play stupid on this one: Had the dealer add it as it was part of the stipulation of the sale, so they did it.
    He did tell me that the procedure is to lay the Matrix bumper (which, I think, comes with adhesive already on it with the protective backing paper) on the back of the Prius. It still has the backing paper on it at this point. Move it around to center it. Then, with a white board marker, partially outline the bumper protector, putting the marks right on the bumper. Then, remove the protective backing paper and align the rear of the bumper protector with the marks. Then, drop the front (meaning, that part of the protector that is closest to the front of the car) of the protector down.
    The trick is to lay the back down first, then drop the front in place, rather than laying it down longways (i.e. Setting the driver's side end down first, then trying to lay the rest of the protector down while keeping it aligned on the bumper).
    I know some decals are added by spraying water on the surface first, then laying down the decal. The water allows the decal to be moved around very easily to align it. Then, the water is squeegeed (sp?) out and the adhesive takes hold. Don't know if this technique could be used with the bumper protector and force is applied instead of squeegee-ing.
    Hope this helps (or at least, makes sense)
    Cheers,
    -bob
    White board marker is used since this easily rubs off.
  12. dgstan
    dgstan Member
    159
    OC
    Here's a picture of the Matrix Bumper Protector. It has little nubbies on the surface of it. It is very easy to install, looks nice, and cost me $33 at the dealer.
    There is also another style (I don't know if it's the "Official Prius" one or it's from a different car). It is the one that hangs over the lip of the bumper. I've only seen them on EBay. My local Toyota dealer knew nothing about any Prius bumper protector.
    The clear version is the "Bumper Applique". I don't know if it's any good.
    DGStan
  13. naterprius
    naterprius Senior Member
    1,843
  14. Ken S
    Ken S Member
    191
    Pittsfield, MA
    Search on Prius on eBay and you'll find a dealer that sells a very nice bumper protector. Cost was about $25, goes on with 3M adhesive strips...very, very easy to install.
    I'd put a link here to it, but I'm short on time and if you do a search here you'll find it...or just hop over to ebay.
    Ken
  15. smtrader
    smtrader Member
    105
    Cerritos, CA
    <div class='quotetop'>QUOTE(naterprius\";p=\"71070)</div>
    This is the one I received...doesn't look like the Matrix one in an earlier post, but seem to fit my Prius bumper nicely. The advantage is better protection, the down side is that it's very obvious. The clear one probably offers less protection but keeps the original color of the car. Anyone interested in my "extra" clear applique? It's sealed and unused.
  16. KTPhil
    1,379
  17. naterprius
    1,843
  18. techogurl
    techogurl New Member
    226
    Fayetteville, AR
    I have the factory decal... but I put clear bra on mine... not that the black wouldn't have looked fine too. So it's a matter of preferance.
  19. KTPhil
    1,379
    Thanks! I ordered it. To be clear, they ship to all of the lower 48.
    It doesn't look to be made exclusively for the Prius, but it looks to fit fine and do the job, including protection of the corner lip. It may be dark grey, not black, judging from the photo.
  20. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    [/quote]Anyone interested in my "extra" clear applique? It's sealed and unused.[/quote]
    I might be! I tried to PM you, but it didn't go through. How much of the bumper will it cover and how much do you want for it? Feel free to PM me.
    Thanks.
