Rear caliper fail in Prius 2013
Discussion in 'Gen 3 Prius Main Forum' started by Rachael71, Oct 14, 2018.
  1. Rachael71
    Rachael71 Member
    46
    28
    Iowa
    So, I bought my 2013 Prius in 2016 with 72K on it. I took it in 3 months ago for an oil change and tire rotation at my local Toyota dealership. A few days after this, my left front tire area started making a horrible squealing sound while driving. Took it to the dealership and apparently a big piece of rust off the rotor had broken off and got stuck in the wheel somewhere. I'm not mechanically savvy so I don't really know specifics, plus my boyfriend had to take it in because I was out of state when it happened and he didn't relay the minutiae of the issue. So that brings us to today. My car just started making a whining noise when backing up and it also makes a noise while driving. It's now coming from the back wheels. I took to the dealership Saturday morning and both my rear brake calipers have failed apparently and now I need them replaced plus rotors and brake pads. These seems nuts to me! I was hoping to have a relatively problem free car and it is not turning out that way. I asked the mechanic if driving habits could have caused this, it was a leased car prior to me buying it, and he said it was just an anomalous failure of a part. I do have an extended warranty that i got suckered into when purchasing the car, the dealer said they "might' cover the calipers but not the pads or rotors despite those parts being destroyed by the failed calipers, they didn't mention anything wrong with the rear brakes at my oil change ( they did say the front pads are thin though) I'm now out at least 800 dollars for the repair. Has anyone had an issue such as this? Is it a known Prius problem?
  2. BZzap!
    BZzap! Senior Member
    1,607
    877
    Unfortunately it sounds like your problem has to do with corrosion from road salt. There is little or nothing you can do. It’s the environment that you live in. All cars suffer this kind of damage from road salts...not just your Prius.
    Rachael71 likes this.
  3. ChapmanF
    15,568
    As Mendel frequently reminds us, the Warranty and Maintenance Guide has a "visually inspect brakes" that pops up every six months or 5,000 miles, except that every sixth one of those (so, three years or 30,000 miles), it drops the "visually" and just says "inspect". That brake inspection is a bit more involved, wheels off, slight disassembly to get access to measure things for wear and at least work things back and forth by hand to make sure they feel greased and move well, with any minor remedies if needed at that time (fresh grease if the old stuff has turned to peanut butter, a rubber boot here or there if the old one is torn, etc.).
    That should have happened twice already by the time you bought the car at 72K, but a lot of people skip it. When that kind of preventive attention is regularly given, it should push off any more drastic brake replacement well into the second 100K for most people.
    The thing is, if that sort of regular attention isn't given, any small thing that happens (some grease dried out, something damaged a rubber boot, etc.) can go undetected and lead to a bigger problem (corrosive water getting in past damaged boot, etc.) over time, that ultimately leads to a brake replacement much earlier than expected.
    Moral, the Prius brakes are very trouble-free and long-lasting, but not completely attention-free; they will give the longest trouble-free service if they are checked now and then, with more than a visual glance.
    The inspection is kind of an ideal DIY task, for anybody who wants to learn to DIY it. I pretty much do it every time I rotate the tires, as the wheels are already off, so why not? It takes an hour or so to do carefully, so at typical dealer labor rates it isn't so cheap, if you can even get the dealer to do it (some will just assure you it isn't anything you need, and hope to sell you a brake replacement later). But if you're doing it yourself and not billing yourself for the hour or two of your time, it usually costs you $0, or a few dabs of grease, or a few bucks for a boot or a spring or the like if you find something with damage.
    -Chap
  4. Rachael71
    Rachael71 Member
    46
    28
    Iowa
    Thanks everyone! I feel slightly better knowing there was nothing I really could have done. I do want to clarify that I didn't buy the car from my Toyota dealership in Iowa city. They have provided excellent service for my car and I would recommend them to anyone ( I usually avoid dealerships like the plague but they are one of the good ones, sigh of relief!) . I bought my car from a dealership specializing in second hand cars and the guy that leased my car from the second hand dealership also took the Prius to them for oil changes and everything else. So my Prius is only now getting Toyota specialized care on a consistent basis. I do still love my car! haha. It's been great except for this brake stuff. As far as a DIY inspection, it sounds great but um, no! Haha- I don't have that kind of know how.
  5. ChapmanF
    15,568
    I didn't either, until I did.
    Maybe the big question is, if you learned how, would your boyfriend see that as a cool excuse to buy tools, or as a reason he'd have to leave you for someone who can't inspect a brake?
    -Chap
  6. High Mileage
    High Mileage Active Member
    135
    231
    2018 Prius Prime
    Racheal71, I was a mechanic for 16+ years. My 2010 Prius has 250K miles on it with all the original brake parts, and the pads still have at least 50% of the material left.
    As BZzap has indicated your trouble is most likely due to corrosion from road salt etc. Here in CA we are lucky the weather helps us out, in the corrosion department anyway.
    If you have the opportunity talk to your Toyota technician when you are at the dealer it might help to understand what is happening. As I tech I was glad to talk to customers and tell them about things I saw with their vehicle. Each person and each vehicle has a story. Talking to people and understanding goes a long way in building a trusting relationship.
    Rachael71 and Raytheeagle like this.
  7. Vincent Detour
    Vincent Detour Junior Member
    44
    Toronto, ON
    Hey Rachel, thanks for posting this, I've had a similar problem. (I also bought a 2013 Prius in 2016 but with 29K on it, now 62k)
    Last year we had a weird creaking sound coming from the rear brakes when braking, it was most noticeable when braking at low speeds, very loud. My wife took it in and they said something about a piece of rust having fallen in, which they removed. That fixed it, but recently it started again, but less, then it went away.
    So from what I am understanding, Chapman or High Mileage or anyone, is that it might be worthwhile to have my Toyota dealer do a proper brake inspection? I have an appointment to have my winter tires put on at the end of November so I could have it done then.
  8. bisco
    49,442
    the brakes should be inspected every 30k, and the caliper slide pins lubed. the rears suffer more from lack of use.
    RMB, Rachael71 and Raytheeagle like this.
  9. ChapmanF
    15,568
    I get to mine about every 6,000 miles or so, just because I do it while I'm rotating tires. Even at that short interval, the sliding motion generally feels a little bit gummy, but frees right up with a little moving the caliper back and forth by hand. And I've discovered things like the need for a new fitting kit (the little springy teflon-coated liners that hold the pad ears) occasionally, by that simple inspection. Fitting kits are cheap. Keeping everything in top shape contributes to keeping the larger repairs away for a long long time.
    Given that it's easy to find small issues developing by a casual inspection at 6,000 miles, it seems to me that a 30,000 mile interval (as the maintenance guide recommends) could sometimes be long enough to find a small issue fairly well advanced. Maybe still correctable so you could fend off a larger repair later, but perhaps with a bit more difficulty than if caught earlier.
    -Chap
    RMB, Rachael71, Tande and 1 other person like this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    You’re stealing @Mendel Leisk ’s Brake thunder :p.
    RMB, Mendel Leisk and bisco like this.
  11. Rachael71
    Rachael71 Member
    46
    28
    Iowa
    I had the piece of rust,too, after they rotated the tires. It was the left front tire making the noise though (took it in and they fixed it for free), then this caliper issue for the back brakes cropped up about 2 months later.
  12. Rachael71
    Rachael71 Member
    46
    28
    Iowa
    So, I did ask how it happened and he said it was basically just a failure of the calipers that couldn't be prevented. My car had been leased prior to me purchasing it and I had visions of someone hot rod driving it (as much as one could in the Prius) but my mechanic said that wouldn't have had an impact. So there you go! I don't know. It's been very wet here recently and wet weather seems to make it worse. I don't wash my car a lot though, perhaps getting to the wash when it warms up a bit during the winter would help (with the corrosion)?
  13. bisco
    49,442
    'he' doesn't know either.:)
    i never wash my car, has no bearing on the brakes, they don't benefit from washing.
    see post #8, and print it out for your mechanic, tape it to his forehead:cool:
    RMB and Rachael71 like this.
  14. Mendel Leisk
    38,708
    That leaves me scratching my head.
    Rachael71 and bisco like this.
  15. Rachael71
    Rachael71 Member
    46
    28
    Iowa
    News update, for any interested to know, I had my Prius fixed today. It turned out both calipers were fine; they were able to get them loose but I still needed to do the rotors and pads. They were mistaken on the previous visit, I guess. But the issue was lack of lubrication and one of the rubber boots, that fit over the calipers had torn. I now wonder if when I hit the curb in my Prius right after I bought it in 2016, if that could have caused the problem. I did post on that as well, my first frantic Prius post. Then i had one when I spilled a bottle of Chardonay in my car. Feel free to roll your eyes at that one. haha
    RMB and Mendel Leisk like this.
  16. High Mileage
    135
    231
    2018 Prius Prime
    Rachael71, thanks for the feedback. Hopefully your brakes are healthy for a while. I am not really sure what to suggest since everyone has an opinion. It seems to me using a carwash at some interval during the winter might help keep the salt damage at bay, but it might not help a bit. My experience is only with living in CA. Here I go through a carwash at least 2x a week. And we don't use salt on the roads. Its dry for most of the time here, one reason why we stay in the news for fires.
    I wish you luck with your car. In my case I love mine. 253K miles now and still going strong.
    Thanks for the laugh about the bottle of wine.
  17. Siward
    Siward Active Member
    296
    124
    Toronto
    I live in Toronto, Canada and we get a lot of rain/snow. My 2012 Prius has gone through three rear brake pads and one set of rear rotors due to uneven wear. In my opinion, the Prius rear brakes do not handle rust very well.
    I plan to start to clean my rear brakes annually starting next year. Let's see what happens.
  18. Mendel Leisk
    38,708
    How many kilometers on it? Also, who's been servicing the brakes? If you're blowing through rear pads, and still on the original front pads, something is not right.
    If you've read my posts for a while, you'll know my bugbear: the rear brakes must be reassemble just so, or they drag and wear the pads unevenly. There's a stubby pin protrusion on the pad backs, and a four-spoke pattern on the piston: it's imperative that the piston is rotated so that the spokes straddle the pin, and everything firmly seated.
    Any application of the parking brakes will attempt to rotate the piston, and the pin in between the spokes is intended to prevent that rotation. If the piston was initially reassembled misaligned, or has managed to rotate, due to not being fully seated, the pin can end up atop a spoke, and then every time the brakes are applied the pressure is terrifically eccentric.
    This condition will be evidenced by bevelled brake pad wear, a zone on the inside face of rotor (roughly 50%) rusty from lack of pad contact, and scoring on the outside face of rotor.
    Rachael71 and Grit like this.
  19. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    In my opinion, anything that gets rusted will eventually go bad, brand don't matter/make.
    Raytheeagle likes this.
  20. Rachael71
    Rachael71 Member
    46
    28
    Iowa
    The front pads were thin also- I was going to replace them at my next 5k check in but ended up doing them the same day as the rear ones. So, that's good news, right? :)
    bisco and Mendel Leisk like this.
