Rear calipers twist in type?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Elt31987, Apr 30, 2019.
  1. Elt31987
    Elt31987 Active Member
    205
    149
    Derry, NH
    I'm going to need new pads and rotors id say in 30K or so. Anyone know if the rear caliper is the twist in type or a standard push in piston?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    How many kilometers has your car done - I'm hoping that mine last the life of the car - when I asked at last service, they said negligible wear at 40,000kms.
  3. krmcg
    2,592
    2,390
    Whittier, CA
    Wow. My 2008 Prius had 120,000 miles and brakes were not even close to needing pads.
  4. Elt31987
    205
    149
    Derry, NH
    Well I guess I'm being very conservative. I'm at 70K miles with 6mm left in the back. So I guess I would need then around another 40-50K
  5. alanclarkeau
    7,044
    7,584
    No mention of pad thickness - I'd be checking what the new ones are - but this shows rotor thickness:
    FRONT
    #5 alanclarkeau, Apr 30, 2019
    krmcg likes this.
  6. Mendel Leisk
    38,729
    Some info:
  7. alanclarkeau
    7,044
    7,584
    At this rate (on Mendel's attachment):
    You've got nearly 150,000 miles before you need to worry about it.
  8. Mendel Leisk
    38,729
    FWIW, our (original) fronts are currently around 6mm remaining, at ~80K kms, and I would change them, at the latest, by 3 mm. So probably around 140~150K kms, at the most. Maybe a lot more stop and go?
    Regardless, every 3 years or 48K kms (30K miles): full inspection.
  9. alanclarkeau
    7,044
    7,584
    If TOYOTA specify 1mm minimum - I reckon that'll do me - TOYOTA are conservative. I suspect mine will go to the wrecking yard with the original brakes - as will the vast majority of PRII.
    krmcg and Mendel Leisk like this.
