Rear camber off? Big deal?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by berderder, Jul 9, 2020.
  1. berderder
    berderder Junior Member
    69
    Connecticut
    22CFFCEC-CFDF-44C4-ACE2-30D70F616998.jpeg Hi all,
    Above is my rear camber results.
    Technician at local shop says nothing to worry about. Is it?
    Dealer wants $275 for shims (on top of regular $120 alignment fee, if I’m not mistaken).
    51,141
    all prius have this. if you're ocd, there are specialty shims or shops available, but most ignore it, as does toyota.
    btw, still the same problem in 2020 models
    snead_c and berderder like this.
  3. Ralith
    Ralith Junior Member
    48
    Bloomington, IN
    My 2017 PP has significant inner tire wear... is thus not an issue? How can Toyota ignore this...
  4. Mendel Leisk
    40,574
    FWIW the spec is roughly -1 (degree), plus/minus .75.
  5. KamiKKazi
    KamiKKazi Member
    91
    58
    OC
    If it drives straight and the tire wear isn’t too bad I wouldn’t worry about it. I have tried to correct some alignment issues with aftermarket suspension and it is a pain in the butt.
