Rear center console of 2007 Gen II
Discussion in 'Gen 2 Prius Main Forum' started by Julia2001, Sep 28, 2012.
  1. Julia2001
    Julia2001 Member
    290
    31
    Maine
    friends. This morning I have been searching threads for far too long and still have not come up with an answer to an issue I'm hoping to correct concerning the rear center console/cup holder thingie.
    When I purchased the car this piece had obviously already had an issue because it falls out very easily. I keep shoving it back in there but it just falls out - pulls away from the console and falls down to the floor.
    Does anyone know how to repair the rear center console so that it stays in place?
    Thanks a million in advance!
    Julia
  2. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Wow Julia, I've had my Prius for 3 years and never even knew it had that rear cup holder.
    Anyway I just took a look and it seems that mine just has two little "bumps" moulded into the plastic of the piece that pulls down, and two corresponding little ridges where it pushes in. That's all it seems there is that makes it "click" into place. Can you check if any of those "bumps" or ridges are missing from yours.
    In any case, it needs very little force to retain it, so if nothing else you could always just glue a small piece of velcro to each side. I'm sure that would hold it.
  3. Julia2001
    Julia2001 Member
    290
    31
    Maine
    Thanks for the great suggestion, uart!
    Have a great weekend..
    Julia
  4. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    Did you know about the 'hidden' storage tray on the front side of the console either?
  5. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yep, great for hiding stuff that one.:).
    BTW. I only found it after a tip off from one of the threads on these forums.
  6. Julia2001
    Julia2001 Member
    290
    31
    Maine
    Hidden storage tray on the front???
    Gotta go out and look! Sounds like more Prius fun! :)
  7. Julia2001
    Julia2001 Member
    290
    31
    Maine
    What I want to know is how you get 57 miles to the gallon! Wow! FIFTY-SEVEN??? Very cool!
  8. MJFrog
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    Doing lots of Pulse & Glide around 35mph (31-39 range) on my daily commute.
    However, if you click where the links go, you'll see I now have a 4kwh PHEV conversion. My current tank as of this morning's stats:
    last filled: 8/7/2012
    gas used to date: 7.92 gallons (per Scangauge)
    miles traveled since fill-up: 1827
    .433 gal/100 miles or...
    230.7 mpg!
    I'll probably need to fill-up in the next week or so.
  9. Julia2001
    Julia2001 Member
    290
    31
    Maine
    Holy moly! That's crazy awesome! Nicely done!
