Rear cylinders
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by shocker, Jun 4, 2013.
  1. shocker
    shocker Junior Member
    89
    Northeast
    My beloved 2004 Prius with 190,000 miles is currently at the dealer to replace the stuts and rear brakes. When I brought it in it also had the abs light on as well as the dashboard brake light. The dealer says that the rear cylinders need to be replaced. I hadn't seen postings in the forums about this and wondered how common this was.
  2. Patrick Wong
    18,200
    6,472
    I assume that you are referring to the rear wheel brake cylinders. Considering your car has logged 190K miles it would be reasonable to replace or rebuild the cylinders to avoid a future brake fluid leak.
