Rear defroster repair
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Daniel Kutcher, Sep 7, 2021.
  1. Daniel Kutcher
    Daniel Kutcher Junior Member
    30
    Richmond, Virginia
    Okay so I found this damage while investigating why my defroster wasn’t working. I want to replace the scorched plastic tab connector, and reattach the tab to the window. Has anyone done this before?
  2. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    there has to be a short somewhere or something else is wrong, otherwise the connector wouldn't be scorched /
    just replacing it is asking for trouble /
    Daniel Kutcher likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Not necessarily.
    The most common failure is caused by the connection point being broken.
    IF it was only partially damaged so that became a point of high resistance............excessive heat at that point might result.
    I suggest that he check with an auto glass shop or two.
  4. adrian-gregory
    61
    40
    GAIA
    Business Ed. Plus
  5. Daniel Kutcher
    30
    Richmond, Virginia
    Well I have a multimeter so I can check all the elements and circuits to make sure they are within spec
