Rear door puncture problem
Discussion in 'Gen 2 Prius Main Forum' started by bogeybob513, May 25, 2013.
  1. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    I have a dilema-some #!# jerk managed to somehow put a hole in my rear door. Upon getting bids to repair it (I have a $500 deductible) I found that it is made of aluminum and that it can't be welded. The lowest price I have is $1200 to replace the door. I'm toying with gluing in a badge of some sort-I can't just let the rain in. The total area affected is less than two inches. Any better ideas out there?
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Just so I understand - is it the left or right side rear door or the hatch door?
    Regardless of which, you should be able to pick up a used door from car-part.com for less than $1200.
    49,617
    i had to have my hatch replaced on my 04 when i backed into an suv. small dent, but the body guy said you can't repair aluminum. $850. for the whole job including paint. i didn't think that was too bad, but that was 7 or 8 years ago. i don't know if it comes with glass or if they swap it. the badge sounds like a pretty good idea if the repair is too expensive. all the best!(y)
  4. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    You could try a vinyl stick on. :) H
  5. Mendel Leisk
    38,804
    I think the badge idea is good. Thanks for the heads-up about aluminum being hard to repair. Being aluminum, at least it won't be rusting out.
  6. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
  7. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    I think BONDO still works on aluminum.
    A piece of aluminum can be riveted or welded to cover the hole first.
  8. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Salvage door, guessing it may be more than the $500 you would pay for the deductible.
  9. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    Duct tape? At places like Staples they sell it in large 12x12 inch sheets in various colors and patterns.
    Your profile lists a 2006 - it may be time to rethink raising your deductible.
  10. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    Thanks-I think I'll do that to seal the opening then glue on a badge to cover the damage. I learned all body shops received a bulletin from Toyota stating they must remove the door or hatch before welding as the computers may be affected. That's why no one will touch it for under $500.
  11. JMD
    3,779
    1,282
    Magnesium is used in car parts and if your welding torch touches it that is a huge fire.
    That is why BS have motors data to see where are Welding not spots.
    Be careful
  12. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    Thanks-putting a reflector back there-it is on a slow boat from China.
    JMD likes this.
  13. JMD
    3,779
    1,282
    If seems everything is made in China.
