Rear Door wont open after 12v battery went flat.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by culp, Aug 15, 2013.
  1. culp
    culp Junior Member
    UK
    Hello
    I had problems with the 12v battery, it was drained and I had to recharge it, which meant disconnecting the negative/ground/earth cable. Ever since the rear door opening button on the outside of the car won't work. Any clues, I tried searching the forum but didn't find anything.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Not necessary to disconnect anything when charging the battery. Use the front jump points under the hood in the black plastic fuse box on the right. Flip up the red plastic cover. That's the positive terminal. Bolt that holds the strut on is negative. Charge my battery all the time.
    To open rear hatch crawl in the back. Open the floor hatch cover and there's a manual lock release on the bottom of the hatch area. Its in the owners manual. Many posts about it on this site.
    KK6PD likes this.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Ed nailed Final Jeopardy, again!:)
    edthefox5 likes this.
