Rear driver side door is locked
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by zfk110, Jan 7, 2022.
  1. zfk110
    zfk110 Junior Member
    88
    Atlanta, Georgia
    Dear PC friends,
    I bought a few weeks back a used gen 3 Prius from 08/2010 : Rear driver side door can't be opened from inside. Or from outside. All other doors open, close fine, with key or front latch, this door won't do anything no matter what I do, using latch or door handles. IDK, how to take it apart and see what's going on with it?
    The window for that door from front switch will go all the way up then it will kick back to half close, if I use back windows switch then it will close all the way to the top if I do it slowly, otherwise it will go up and then come down to half way.
  2. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    If I had to guess, I would speculate that your original rear drivers side door may have been damaged in an accident and was not properly repaired.
    I've never had to do this with either of our Prii, but on other vehicles I have pried off the plastic trim on the inside of the door to get at latch attachments and power window motors. I can't imagine that the Prius doors have been designed any differently than any other car. It's probably best to use a pry tool to do the job, something that you could get at a Harbor Freight store, but if you are careful and go slowly you could probably use a large flat head screw driver as well to get the trim off. Before prying on the trim, though, make sure to take out any screws that you can see and loosen any pieces of chrome or plastic that they are holding down by gently wiggling on them. After removing the trim, I would expect that you might find damaged wires and latch pieces that will have to be repaired or replaced. The best source for replacement of those items is your local salvage yard. If the window will move in its present state, even though it does not do what you want it to, I would not expect that you would need to replace the window motor, which is probably the most expensive part, so that's good.
    49,432
    see if the bolts for the rear door are exposed when you open the front door.
    davecook89t likes this.
  4. davecook89t
    1,057
    789
    Four Touring
    Right, I guess if you can't get the door open at all, it may be hard to get the trim off, as it may be jammed against the weather stripping around the inside of the door frame. Hopefully, the door could be unbolted from the rest of the car by going at it from the front edge, and then after removing the door you should be able to pull the trim off.
  5. ChapmanF
    15,561
    It's a challenge, but I've seen success posts getting the trim off with the door closed, at least enough to get access to the latch.
    In the worst case maybe the trim doesn't perfectly survive and you've got some of that to replace. There aren't a lot of other options.
