Rear electric window not working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JamesLondon, Sep 21, 2017.
  1. JamesLondon
    JamesLondon New Member
    London
    Active
    Hi everyone, I wonder if I could get some help from the experts!
    The drivers side rear electric window has stopped working. All the other windows work fine.
    On the driver window control there is a faint green light on all the other windows switches except for this one. There is no light on the window switch on the rear drivers side door either.
    Does anyone know what might be the cause of this? Is it the motor or something else?
    Thanks,
    James
    52,390
    does it work from the drivers switch, or the passenger door switch?
  3. JamesLondon
    London
    Active
    No it doesn't work from either switch
    52,390
    likely a burned out motor. you can test it by removing the interior panel and putting 12v to it.
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,731
    1,767
    Bay Area
    I would check the fuse first
  6. JamesLondon
    London
    Active
    Thanks - I will try 12v on the motor.
    Could it be the fuse if its just one window and the other four are ok?
  7. bisco
    52,390
    i was thinking the fuse but figured only one for all windows, not sure without checking, but nutz knows his stuff.
  8. frodoz737
    frodoz737 Top Wrench
    4,720
    2,517
    33
    Always check fuses first...always. Driver's access switch to RR window "also" not being illuminated "suggests" looking at that switch next, because the rear switch comes after in the logic control.
    Included "US" WDM to help.
  9. NutzAboutBolts
    1,731
    1,767
    Bay Area
    if the fuse is good, I would try to back probe the left rear power switch to see if there is power going through it. Do it on the Master switch first, then the rear switch itself.
    NYC Prius Taxi and frodoz737 like this.
