Rear Ended!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jimnjo, Dec 28, 2007.
  1. jimnjo
    jimnjo Member
    117
    2015 Prius c
    I am sad to report that our Prius has been hit - hard - in the rear. I am curious to learn what others have experienced in terms of potential pitfalls in the repair and problems later that may have resulted from undiagnosed damage or things that simply broke down later as a result. Here are some details: Rear ended on the expressway (yup, and hard too) at highway speed, not at all sure of other driver's speed. 2006 model with about 30,000 miles. The other car rode up and over the bumper a bit, and pushed the back of the car most of the way to the back seat, without however getting into the rear doors. The synergy drive worked after the accident until I turned it off; then the dash would light up, but it would only go into neutral. It is at a body shop that the local Toyota dealer uses, and they claim to have experience going back to the first Prii. They believe (in preliminary analysis) that the main battery is not impacted at all, and the frame damage is 'extremely minor.' Initial estimate is about $8,000 and change, with the possibility of another grand or more if there are technology issues (which would be fixed at the Toy dealer). The estimator is suggesting that there is little likelihood of totaling the vehicle. Any comments or experiences? Jim
  2. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    No experience, but I feel truly awful for you.
    Do post photos, especially if they are able to fix it... before and after. (good documentation for you, too)
    Good luck, and all the gods bless you.
  3. Skywalker
    Skywalker New Member
    Please post pictures if you can. I work at a body shop so I'll be able to help you out with any questions.
    If it's a hard hit and I'm trying to vision it I wouldn't be suprised if they total it. If the damage amount exceeds what the vehicle is worth ( by a percentage) then you get to buy a new one.
    After a wreck a lot of things can go wrong long after the hit. it might dog track a little bit going down the road which will cause irregular tire wear and bearing failures. It's not common to see it with cars but you will see it with trucks when the rear axle gets hit and tweaks the frame a bit. It's like you going down the road slightly sideways.
  4. Prius101
    Prius101 Paid off Prius Member
    118
    Port Orchard, WA
    When my poor Prius got hit, it crumpled most of the right rear. I had some canvas bags in the hatch that were unreachable until in the body shop. I was very lucky that the body shop was experienced with Prii and worked with the Dealership. The dealership sent a van to pick up the hybrid batteries before they started working on the replacements - safety reasons. But the dealership apparently did testing of it while they had it - and after the body work was done replaced it in the car - checking wiring etc at the time.
    I was really pleased that the people in the body shop allowed me in to see the car at various times while they had it in the shop. Also lucky that the other insurance company agreed to all new Toyota parts.
  5. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    Such a severe accident repair will show up in CarFax report when you try to sell it later. Most private buyers who use CarFax will be turned off by this repair. That means depreciation of your Prius even if they can repair it nicely. If you trade in your Prius, it probably won't make any difference if the dealer will not check CarFax and send it directly to auction. More and more people rely on CarFax (or AutoCheck for that matter) to investigate the history of any used vehicles.
    I am just suggesting that you probably should deal with the insurance company from this depreciation angle to cover your future loss in value due to this accident repair. Make sense?
  6. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    I'm sorry to hear about your accident, :eek:Jimnjo. Glad to hear that you are still around. Physically, I hope you are alright. Good Luck on the repairs and hopefully you can get your Prius back on the road.
  7. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    The traction battery needs to be pulled before it goes into the paint booth as the heat used to cure the paint will damage the battery. My condolences.
  8. jimnjo
    jimnjo Member
    117
    2015 Prius c
    Thanks for the kind words.
    I thought of taking pix a little too late...the eve of the accident I was simply too rattled to think of it and now it is in a body shop 200 miles away. I do wish I had some!
    I had considered the accident reporting that will now follow this car, but had not thought of hitting the insurance company up for accelerated depreciation. Sounds like a long shot, but worth asking about anyway.
    The adjuster has agreed, generally, with the appraiser and they will go ahead and fix it. We had some hopes, actually, of it being totaled so that there would be less potential for trouble down the road. But the guy at the body shop is quite reassuring, suggesting that any tech issues will be dealt with, and by Toyota techs. And that they will be thorough in their analysis and repair. The shop has a very good reputation.
    Jim
  9. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    I have no experience with it but am sorry to hear about your accident.:( It sounds like the car did a good job of keeping you from being injured. Keep us posted on the progress and, watch your back around the insurance company. Good luck.
  10. jimnjo
    jimnjo Member
    117
    2015 Prius c
    It is true that we felt that the car took the brunt of the impact and left us shaken but unhurt. It also handled very well after being hit, albeit almost straight on. There was a brief moment that I thought we would lose control but it quickly straightened out and we were able to coast to a safe stop. Jim
  11. diamondlarry
    559
    Elkhart, IN
    I wonder if the VSC was what made it possible for you to maintain control?
  12. eboyle
    eboyle New Member
    Kansas City
    What an amazing similarity... We were just rear ended Dec. 18 in our 2006 Prius. We were at a complete stop on a busy street with my left turn signal on waiting for oncoming traffic to pass so I could turn left.
    I just happened to glance in the rearview mirror in time to see a full sized pickup flying toward me. It was a 16 year old kid with another 16 year old in the pasenger seat. He never swerved, hit his brakes or anything. I estimated he hit us at around 45 mph. It threw the car directly forward appx. 50 feet. We were fortunate that we were not thrown into the oncoming traffic and hit head-on.
    Very similar to your Prius our rear end compartment crunched like an accordian, but the passenger area was pretty well intact. The rear doors were hard to open but they still opened and closed. Our rear bumper was left hanging on the front of the kids pickup.
    The body shop guy was very impressed with the way the Prius handled the impact and said he sees cars all the time that do not stand up nearly as well and he could tell that we were hit very hard. The rear passenger compartment didn't have much damage, but I did lay the seat down and it was broken. I'm so thankful my kids weren't in the backseat.
    The airbags did not deploy - which I am told they shouldn't on a rear-end collision, but I noticed a very fine white powder inside the car immediately after we were hit. Anyone have any idea what that could be?? A guy at Toyota said it sounds like an airbag malfunctioned but the body shop guy said there is no way to inspect the airbags without really tearing into the car and he believes it is a total loss so he doesn't want to put that much time into it. He said he would be sending a recommendation to the ins. co. tomorrow (12/31) to total it.
    Never been in an accident before... anyone have any advice on dealing with insurance? I want a NEW Prius, but I really don't feel like I should be out of pocket to get one and it should have all the features of our old one. Any advice would be appreciated!
  13. jimnjo
    jimnjo Member
    117
    2015 Prius c
    Never been in an accident before... anyone have any advice on dealing with insurance? I want a NEW Prius, but I really don't feel like I should be out of pocket to get one and it should have all the features of our old one. Any advice would be appreciated![/quote]
    We haven't been in a wreck, until this one, in 20 years or more. But some advice I got at that time (and some since) may be helpful in dealing with insurance. First off, you *should* be able to get the equivalent car, options and all (and, I would argue, with any added warranty that you purchased), with similar number of miles. If they offer you an amount, call around and make sure that you can actually buy the car for that amount. If you can't, ask them to simply find you a car that *does* have everything you have lost. Back it up with actual prices if you can, of equal autos. Also, realize that there is a chance that they *will* offer you less, and maybe even show you some fine print somewhere in the policy that makes it look like that is all you are entitled to. This used to be - and probably still is - a fairly common practice and is almost always hooey. Be ready to balk at the first offer it is - or seems - low. They are motivated to settle claims rapidly, and hope that you will just go for the offer. Hopefully you will have a good experience from the get-go, but don't back down. I have a friend who has a good legal practice (in New Mexico) representing people who have been wronged by insurance, and last I knew he was tending to win (often simply with a note on his letterhead). Hope all goes well without any of the recourse I have mentioned... Jim
  14. Bobwho
    Bobwho New Member
    68
    Chicago area
    First thing to consider about the accident - were you injured in any way?
    If yes then get a lawyer to maintain your rights. Even if you were not injured you will possibly want an attorney to get your deductible back from the other party,
    Next thing to consider - what insurance does the other party have? Ask your insurance agent for their opinion of the other parties insurance company. You will need a lawyer if the other party has low coverage. An attorney is needed to negotiate with your own insurance company for you. They will talk you out of things if you are not represented by an attorney.
    Then were tickets issued? Go to court for all trial dates. Do not ask just go and testify as to the facts. This is important latter in time for many reasons that I am not qualified to answer,
    Go to the shop where your car is being repaired and take pictures of the damage even if the car is torn apart. Document, document, document, then take more pictures of the accident scene. Just collect every bit of information that you can get. If you should need to defend yourself in court, do not tell me that it cannot happen, you will have the information that you need to prove your side of the story.
    I know that this sounds like a lot to do but believe me when it comes to accidents there is never enough proof of what happened.
    Go to the police department and get a copy of the accident report. A real official copy filled out by the police officer that did the accident report. You will find more information than you would believe in that document.
    Send me a PM if you want more information - your profile does not have the state that you live in so I am left in the lurch for giving your more about your state.
    Martindale Hubble is the reference used to find a good attorney.
    http://www.martindale.com/
    Best of luck in Americas legal system.
  15. patsparks
    10,664
    567
    Adelaide South Australia
    I just let my insurance handle it all. I know they are a good company from 10 years working for a crash repairer. They look after all the money side of it even the excess all I have to do is pick up a hire car(paid by insurance) for the duration of the repair and if the car is a write off and under 3 years old I get the cost of a new car plus on road costs paid in full. Any personal injury it would pay to have a lawyer even if just a sore neck or shoulder, just in case. Lawyers have a way of getting higher payment but taking more than their share in fees.
    The first thing you should do in a accident you need to do before it happens, get insurance with the best company available. Ask a crash repairer who deals with many insurance companies and has a good reputation who is the best company to deal with, then even if it costs a little more go with them.
    I use South Australian RAA insurance for all 3 cars and my home and contents. Cheaper insurance is less insurance.
    Off my high horse, good luck with a favorable outcome.
  16. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    Sorry to hear about the accident, glad you are ok. Like someone said earlier, make sure you get the depreciation value taken in to account. Perhaps the other party's insurance should pay that to you.
  17. eboyle
    eboyle New Member
    Kansas City
    Thanks Bobwho,
    I was not injured but my wife's back, neck and shoulder are still very sore and she is still taking pain pills. She was miserable all through Christmas and New Years. So far insurance has been taking care of everything. We have a claim number and the chiropractor and Dr's office is sending everything directly to them.
    We are in KS. I didn't see a place on the profile to put my state...
    Anyway, I spoke to an attorney who told me that in KS we are considered a "no fault" state. I'm still trying to figure out exactly what that means, but she said what it means to me right now is that the first $2,000 of medical bills will go through MY insurance and if it goes above that we will have the right to take the other driver to court.
    We heard back from the ins. co. yesterday, they said the shop has recommended that the car is a total loss but the ins co is sending it to their "Total loss" department and we should hear back today or Monday.
    I'm really anxious to hear what they offer.
    Thanks for the advice and links!
  18. mcbean
    mcbean New Member
    Orange County, California
    Rear Ended in the Bay Area
    I've read the posts before but never posted anything.
    Friday night I was rear-ended just before the toll booths on the Oakland Bay Bridge. (A guy in his pajamas hit me with his Toyota pick-up truck because his slipper slipped onto the accelerator. ARGHH!)
    Anyway, I had it towed to the first open body shop in San Francisco, and it's sitting there pending the insurance adjuster's visit. I had to fly home to the OC and rent a car. I must say the "crumple zone" did a good job of protecting me and I'm proud of my little car. I was very lucky to find, once I could get into the back compartment, that my $6000.00 worth of cameras, lenses, and a Mac were all fine.
    Does anyone have any advice or experience with an accident like this? I've attached a picture if it helps. I have no idea what's all back there and somehow I feel that the car will never be the same. If the car is totaled, I'll lose my carpool stickers, I think, since the state has run out and they aren't transferable. Anyone know anything about that?
    Thanks!
  19. Ach
    Ach Junior Member
    Fullerton, California
    Re: Rear Ended in the Bay Area
    Sorry to hear about your accident. Can't help with the accident info but I think you can get replacement stickers per the CA State website:
    Clean Air Stickers - High Occupancy Vehicle (HOV) Lane Usage
    Good luck...
  20. Submarine Dude
    Submarine Dude Junior Member
    73
    Glendale, AZ
    Nope, the stickers are gone. I've been through the same thing. Replacement stickers are only issued to the original VIN and are absolutely not transferable to another vehicle.
