Rear Ground Clearance - Dragging on Incline
Discussion in 'Gen 3 Prius Main Forum' started by divango, May 13, 2010.
  1. divango
    divango New Member
    16
    Tennessee
    I
    Have any of you had a problem with the rear valance being too low? I have a very steep driveway and last week hit the approach at a weird angle, the rear corner caught on the drive and popped the panel out on the lower side. I was able to pop it back into place without any damage but this is something to be aware of... I wonder if the Nissan Leaf will have more ground clearance? That will be the new stable mate for the Prius.
    Nissan Leaf Forum and Owners Group
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Yes, I've dragged Pearl's rear a few times, mostly on "curbs" at the entrance to driveways (backing in - going in forwards would have broken off the front chin spoiler).
    Take it at an angle to increase your clearance.
    Any "aero efficient" car will have limited ground clearance. If you think the Prius is low, try a 3rd gen RX-7. It's a nightmare to drive!
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Some driveways and their entrances are badly-designed and can hit the underside of even normal height cars.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Yes front and rear, the car is to low. My BMW was worse though. I would be willing to sacrifice a little gas mileage for another 1/2" of clearance.
  5. alkurtz
    alkurtz Junior Member
    Mahopac, NY
    Had my Prius for 2 weeks and this is the only problem. As I come down my steep driveway and turn onto the road, I scape the bottom. Can't really figure out if it is the front or back yet,
    I've lived her for 27 years and owned many cars, minivans, and SUVs, and this is the only car that has had a problem.
    I've been taking it real slow at the bottom of the driveway but it is rather disturbing and I haven't a clue as what to do about it or whether I am causing or could cause damage to the car.
  6. Joe166
    Joe166 New Member
    720
    96
    South Florida
    I have only had a problem when I back into a parking space with a bumper stop and go too far. Otherwise, I guess I have learned my lesson since my other car is a 2004 Thunderbird which has much less clearance and used to scrape getting into my garage at work.
  7. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    I don't have a problem in my sloping driveway but I am always scraping the front underside against high parking curbs that you can't see.
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    My rear end drags from time to time. ;)
    Tom
  9. socratesthecabdriver
    283
    31
    greece
    low??? try a peugeot 407 , thats low !!! i drove the cab by all the points the peugeot used to hit and nothing ! the car is ok although more ground clearance with more shock absorber travel is always a good thing!
