Rear hatch release
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Paul Gregory, Jul 27, 2025 at 9:50 PM.
  1. Paul Gregory
    Paul Gregory Senior Member
    1,650
    411
    Alberta
    2024 Prius Prime
    XSE
    I would like to know if there is a way to open the rear hatch from the front driver's seat. If this topic has been discussed, I haven't found it, and I apologize if it has.
    I know about the manual release handle, but I am unable to crawl into the back to access it.
    #1 Paul Gregory, Jul 27, 2025 at 9:50 PM
  2. Hammersmith
    Hammersmith Senior Member
    2,072
    2,060
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    If you have the power rear hatch - yes. Button next to the fuel door release.
    If you have the manual rear hatch - no.
  3. Paul Gregory
    1,650
    411
    Alberta
    2024 Prius Prime
    XSE
    The only way I've found is to press the switch in the lift handle.
  4. ChapmanF
    17,462
    I had a work colleague with a gen 3 who was doing some ride-share driving, and wanted a way to unlock the hatch from the driver position for the riders' convenience.
    We looked on the wiring diagram and saw that the wiring from the release button in the hatch came along the floor and through the junctions behind the driver's kick panel, making it very easy to add another button in one of the switch blanks in the instrument panel.
    That was gen 3, but it wouldn't surprise me a bit to find similar wire routing in gen 5.
  5. Hammersmith
    2,072
    2,060
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Like I said:
    If you have the power rear hatch option, there's a button up front next to the fuel door release button.
    If you don't have the power rear hatch option, there is no way to open the rear hatch from the driver's position.
    There's nothing more to elaborate on. You either have the power rear hatch option or you don't.
  6. Paul Gregory
    1,650
    411
    Alberta
    2024 Prius Prime
    XSE
    I know I don't have that button. There are 3 buttons; fuel door, auto headlight dimming and inverter power.
  7. Hammersmith
    2,072
    2,060
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Does the rear hatch completely open by itself when you press the button in the back? You press the button and stand back and the hatch motorizes up completely without you touching it?
  8. Paul Gregory
    1,650
    411
    Alberta
    2024 Prius Prime
    XSE
    I don't have power assist, just gas shocks.
  9. Hammersmith
    2,072
    2,060
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Then why did you keep asking?
    Back to my original post with emphasis added:
    You:
    Me:
  10. Paul Gregory
    1,650
    411
    Alberta
    2024 Prius Prime
    XSE
    What did I "keep asking?" That makes no sense whatsoever.
    So you have an answer, good for you.
  11. Paul Gregory
    1,650
    411
    Alberta
    2024 Prius Prime
    XSE
    It would be nice to find out how to connect it. I have a feeling that the dealer would make it an expensive upgrade.
  12. ChapmanF
    17,462
    The dealer might just say "that's not an upgrade we offer."
    A local independent auto electric shop or audio/alarm installer might take it on, if you weren't inclined to DIY.
    DIY would probably be straightforward after a glance in the wiring diagram.
    Toyota Service Information and Where To Find It | PriusChat
  13. Paul Gregory
    1,650
    411
    Alberta
    2024 Prius Prime
    XSE
    Calling the dealer to find out...
    Found out; it is a dealer upgrade. Costs $260 just for the button, installation is extra.
    So. quite expensive.
  14. bisco
    51,246
    seems to me that you should be able to install a remote control switch inside the hatch.
  15. Paul Gregory
    1,650
    411
    Alberta
    2024 Prius Prime
    XSE
    I'm thinking that when my remote relays arrive from China, I'll be able to tie into the hatch release circuit somehow. I suppose I'll have to dive into the technical manuals.
  16. bisco
    51,246
    i would just open it up and check the wires
  17. Prodigyplace
    12,416
    11,683
    Central Virginia
    A dealer would likely refuse to do it because it is not sanctioned by Toyota US
  18. Mendel Leisk
    40,666
    Wiring so it only works if the car's in Park (or similar) seems a good ploy.
  19. Paul Gregory
    1,650
    411
    Alberta
    2024 Prius Prime
    XSE
    It's not an unsanctioned mod. It's an actual dealer upgrade.
  20. bisco
    51,246
    if it's wired to the hatch release button, it would only work while in park
