Rear hatch won't open with car running
Discussion in 'Gen 2 Prius Technical Discussion' started by ToySup, Oct 17, 2012.
  1. ToySup
    ToySup Junior Member
    Twin Cities
    Actually its inconsistent. Many times with the car running and in park, I jump out to access the rear hatch. Sometimes it will open and sometimes it will not. When it doesn't open, I have to turn off the car and then the hatch opens.
    Any idea why this happens? Very inconvenient to have to turn off the car.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Could have something to do with the doors being locked. Try powering up......
    1) lock the doors......open driver door & attempt to open hatch.
    2) unlock the doors.......open driver door & attempt to open hatch.
    Did the hatch open with #1......#2......both.......neither?
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    I second the locked comment. Automatic unlocking doesn't work with the car running.
    Tom
  4. pjc
    pjc Member
    139
    46
    Bloomington, MN
    Yep. SMS and/or FOB button will not work with the car running. The lock/unlock switch on the driver's door does, though...
  5. drysider
    drysider Active Member
    823
    335
    Liberty Lake WA
    I am not sure about the hatch opening while the car is running, but it will not unlock unless you use the driver-side unlock button. The inconsistency may be that the hatch is or is not locked when you put the car into Park.
  6. qbee42
    18,058
    3,076
    Northern Michigan
    It's not that the hatch won't open when the car is running, it's that the SKS and Fob are disabled when the car is running, which means you can't unlock the hatch using either. As stated above, the unlock button on the inside of the driver's door will work.
    Tom
  7. Marty2go
    Marty2go Junior Member
    39
    Ohio
    Four Touring
    I think this is because your spedo or dash lights are out, no lights on dash. I would have to turn the car off to get the hatch open. When I unhooked the 12volt and got the dash lights and spedo back on the hatch would open again.
  8. ebikeman
    ebikeman Junior Member
    Northwest
    I checked and mine will not open with the car running. My first thought was that's a good design. Toyota thinks of everything.
  9. ChapmanF
    17,347
    As mentioned upthread, if you want to open it with the car running, just touch the unlock button on the driver's door armrest controls. Then you can go open the hatch.
    The things you can't do are just open the hatch by unlocking with the fob button, or (smartkey version) by walking up to it with the fob in your pocket and grabbing the handle. Those only work when the car isn't on.
  10. Paul Gregory
    Paul Gregory Senior Member
    1,508
    391
    Alberta
    2024 Prius Prime
    XSE
    I don't think I've ever been able to open the hatch while the car was on.
  11. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    I do not know why you would respond to a 12 year old thread, but for YOUR car it sounds as if you have a failing capacitor in the Combination Meter. That prevents the CM ecu from turning on, which causes problems such as no gauges or dash warning lights, tailgate release inop, etc.
    There's a stickied thread about DIY repair (towards the top of the Gen2 "Care, Maintenance" thread), or you can remove the CM to have someone else fix it.
    TexasHybridBatteries.com has been recommended - they can repair your CM, or sell you an exchange unit that's programmed with your odometer value.
  12. Marty2go
    39
    Ohio
    Four Touring
    This is one of My most trusted members. Everything He posted here is true but without experience, He doesn't know that even using the arm rest button for the locks will not unlock the hatch when the dash lights (spedo, gas, etc) are out. I fought with this untill I figured it out. Thanks ChapmanF for your unwavering accuracy with your posts. With the dash lights out you must shut the car off and hit the button twice to open the hatch. I fought with this for a long time before I figured it out.
    #12 Marty2go, Jul 4, 2025
