Rear Left Window Keeps Rolling Back Down
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Corrin King, Oct 10, 2020.
  1. Corrin King
    Corrin King New Member
    Los Angeles
    2013 Prius Persona rear left window keeps rolling back down when it reaches the top. Track clean, battery reset, does anyone know another fix or where I can get a replacement sensor? Pain in my nice person to tap it into place, especially as it's the one I can't see the most from the drivers seat.
  2. SB6
    SB6 Member
    324
    71
    Have you tried a reset? IIRC, the procedure to reset is to roll up the window, then hold the switch in the up position for 10 seconds, using the respective switch (as opposed to the driver's switch)
  3. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    Does anyone know if the process is the same for 2010 Prius? My passenger window has recently started doing this.
  4. ASRDogman
    ASRDogman Senior Member
    7,862
    4,005
    Have you tired it?
    It's pretty much the same for all of them.
  5. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    Nope, stuck at work...figured I'd hope for an answer (if it were different) before I got off work.
    Thanks for the confirmation.
  6. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    Didn't get a round tuit until the next afternoon, but that worked like a charm. Thanks again for the confirmation.
    ASRDogman likes this.
