Rear license plate bulb help.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by BreitrthnU, Jun 22, 2012.
  1. BreitrthnU
    BreitrthnU Can you smell the premix?
    255
    50
    Tampa, FL
    Anyone know how to access the rear bulbs for the license plate. I just got the Ijdm deluxe LED kit but cant figure out how to get them out. I tried a search but had not luck, any help would be appreciated thanks
  2. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    There are 2 plastic covers on the hatch door, one for each bulb. Twist the bulb assembly (i forget which way) to take it out of the housing. Pull on the bulb.
    Mendel Leisk and BreitrthnU like this.
  3. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    It's in your owner's manual. This is from the 2010:
    Mendel Leisk, gggGary and BreitrthnU like this.
  4. BreitrthnU
    255
    50
    Tampa, FL
    Derf thanks guys
    PC36100 ? 2
    gggGary likes this.
  5. gggGary
    gggGary gggGary
    79
    27
    Baraboo WI
    2023 Prius Prime
    XSE Premium
    The covers have a small recess near a top corner to start the process. Note the top needs to be popped loose first, the lower edge clips have a 90 degree bend and can not be pried straight out.
    Some cheap LEDs I had around from motorcycle gauge use went right in, turn on headlights and confirm bulbs are inserted the "right way around" so they light before closing up the covers. ;^)
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,352
    2,346
    Taylors, SC
    These work perfectly. Replaced map lights and more.
  7. durr
    durr New Member
    NY
    Can also vouch for SIRIUSLEDs. Have replaced all T10's with them besides the ones that turn on with the sun visor's mirror. Running strong for about 2-3 years.
    However they were too bright for parking lights and used these SIRIUSLEDs instead.
    https://amzn.to/36F856y
    #7 durr, Feb 2, 2021
  8. Mendel Leisk
    40,575
    Yeah that’s a gotcha for me; I do it so infrequently I forget. That recess is a clue eh.
