Rear License Plate Frame Mod ... To Drill or Not?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Ray66, May 22, 2010.
  1. Ray66
    Ray66 New Member
    153
    Miami, FLORIDA
    Rear License Plate Frame Mod ... To Drill or Not? *Pics*
    Hello Group -
    I'm not sure to drill to extra holes to accommodate my new plate frame. Also, can I use a tinted shield over the plate or am I risking a ticket ?
    Thanks in advance.
  2. Ray66
    Ray66 New Member
    153
    Miami, FLORIDA
    Here's the tinted one ...
  3. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    The tinted frame depends on the state.
    As for the 4 hole plate frame, I would not drill. They make lots of nice two holed plate frames...
    If you really want to ise that one I would use a small screw with a flat washer on the back. That will secure the plate to the frame and then you can attach them frame to the car using the stock two holes at the top.
  4. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Just use the two on top. The top holes I think have something behind them to allow the screws to grab.
    There might not be anything down below for them grab.
  5. Ray66
    Ray66 New Member
    153
    Miami, FLORIDA
    California or/and Florida ?
  6. SW03ES
    2,480
    176
    Gaithersburg, MD
    You'd have to call your local DMV...
  7. justin time
    justin time Junior Member
    58
    The existing mounting points have captured nuts, so all that's needed are machine screws. If in an area where plates are commonly pilfered, locktite would be a good idea, and also don't forget to slit your anual sticker if your state uses them.
    I sure wouldn't want to drill into my car unless it was already pretty ugly to begin with. Not sure what the benefit would be, and a potential starting place for corrosion.
    As to obscuring your plate, only one thing comes to mind...
  8. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Just glue the caps onto the frame for the two lower holes. I used clear silicone adhesive.
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    This would be my concern
  10. car2lvr
    car2lvr Junior Member
    34
    North Burbs, IL
    Use adhensive-backed bumpers (like the one for the cabinets) on the bottom back of the license plates. It will give you some clearance to mount a nut and avoid damage on the car paint.
  11. Patrick Wong
    18,200
    6,477
    What is your motivation for installing this tinted license plate cover?
    In any event, here are some excerpts from what appears to be the relevant state law.
    California:
    V.C. Section 5201 - Positioning of Plates
    A casing, shield, frame, border, product, or other device that obstructs or impairs the reading or recognition of a license plate by an electronic device operated by state or local law enforcement, an electronic device operated in connection with a toll road, high-occupancy toll lane, toll bridge, or other toll facility, or a remote emission sensing device, as specified in Sections 44081 and 44081.6 of the Health and Safety Code, shall not be installed on, or affixed to, a vehicle.
    Florida:
    HSMV: 2007 Legislation Affecting Traffic And Motor Vehicle Laws
    320.061No person may apply or attach any substance that would obscure a license plate or interfere with the ability to record any feature or detail on the plate.
  12. Ray66
    Ray66 New Member
    153
    Miami, FLORIDA
    The tinted plate cover is simply a protector of my personal plate and blocks UV rays, so I heard. In any case, I will go ahead and use the clear acrylic shield instead.
    About drilling 2 extra holes at bottom to mount the two screws.... I did this on my 1993 C4 Corvette ( 16k miles ), although fiberglass and never had a problem. I simply drilled two small holes, then ss screws and I even live on the Beach .... no issues with corrosion.
    In Florida with the humidy we have any adhesive will not stay on for long periods. I could cut off the screws really short then add a simple skinny nut or just drill in to the body.
    I don't sweat the small stuff so 2 small holes seems less hassle and easier. My Prius is a 2006 w/almost 70k miles so it's not new by any means and already has scuff marks on the body from normal use and abuse.
    Thanks to all.
  13. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    No rust on the vette cause it was fiberglass. Being in Florida, the metal will rust in no time. Even if your Prius isnt new, why would you want to take the chance of rust?
  14. Supreme
    Supreme Hypebeast
    182
    Philly
    A bit puzzling that you would care about the condition of a license plate to protect it from uv rays and other things but you'll drill into your car! lol. I say just use the top 2 screws for the frame and ditch the tinted cover. Don't want to give the police a reason to pull you over if you're riding dirty.
