Rear lights fuse
Discussion in 'Prime Main Forum (2017-2022)' started by RomanCro, Jan 9, 2020.
  1. RomanCro
    RomanCro Junior Member
    63
    Croatia
    2018 Prius PHV
    i think my rear light fuse is blown up. Can someone helpme find the fuse? I have pic of fuse box under the hood, but which one is it?
    SM-G973F ?
  2. Chazman62
    Chazman62 Member
    108
    65
    Long Beach, CA
    2020 Prius Prime
    I think you are looking at the wrong fuse box.
    Many today's cars have 2 fuse boxes. One under the hood (for mainly under the hood components) and another one under the dash just above your left knee area when you are sitting on the driver's seat. Check the one under the dash. Owner's manual would help.
  3. gaiskid
    gaiskid New Member
    Nanaimo, BC
    2020 Prius Prime
    Can someone tell me how to remove the driver's side fuse box cover on my 2020 Prius Prime. The pic in the manual is not very helpful
  4. jakilo
    jakilo New Member
    roma
    The brake lights work however. What is actually is the name for the wire, and where would it be able to be found?
  5. Elektroingenieur
    2,515
    3,258
    Three Touring
    See the Electrical Wiring Diagram (more info). As far as I know, Toyota doesn’t give the wires names or numbers in the service documentation; wires are identified by connector, terminal, and insulation color. The complete wire harnesses have part numbers, which are listed in the Electronic Parts Catalog, Figure 82-02, Wiring & Clamp, for the relevant model and year.
