rear right passenger vent
Discussion in 'Gen 3 Prius Main Forum' started by Gnarly, Feb 15, 2020.
  1. Gnarly
    Gnarly Member
    142
    44
    the vent at the back seat next to the right rear passenger, I think is for the hybrid battery. I'm hearing air coming out of it or it's sucking air.
    Anyone know why or what it's doing?
    thanks.
  2. Mendel Leisk
    40,576
    Should be sucking air in, for the hybrid battery.
  3. davecook89t
    davecook89t Senior Member
    1,076
    810
    Washington State, Florida
    Four Touring
    Hearing that fan running is usually not a good thing. It almost certainly means your battery is overheating and possibly on the verge of failure. Have you ever cleaned the fan? There are videos on YouTube showing you how to do it. Hopefully, the fan just needs to be cleaned and doing that will cause it to run at a lower speed. If that doesn't help, you'd better start planning to refurbish or replace the hybrid battery.
  4. Calimobber
    Calimobber Member
    94
    83
    Death Valley
    Definitely dont assume his battery is failing just because he can hear the fan. Thats just going to freak himout for no reason.
    I do agree its good to check the fan if its never been cleaned, It might be going bad or maybe you just never noticed the sound before and its still working just fine. It only takes 15-30min and its very simple with all the videos online to follow.
  5. Gnarly
    Gnarly Member
    142
    44
    I used this video in YouTube to help me replace the rear right taillight. it suggested to peel back the cover from the taillight to the front where the vent is.
    I turn the car off and turned it back On. and the sound when away.
    I'll have to go back and check my work a lot more closer when I peel that back to make sure things align properly or back to how it was.
    I'll keep this post updated.
  6. bisco
    51,142
    I don’t think the battery cooling system is connected to the taillights
    davecook89t likes this.
  7. Graeme1949
    Graeme1949 Member
    51
    47
    Atlanta, GA
    No, but the side panel you have to remove to do the tail light change, ALSO exposes access to the hybrid battery vent fan.
    -Graeme-
    2004 Prius with >190,000 miles.
    Sent ?.
  8. Gnarly
    Gnarly Member
    142
    44
    I didn't alter anything with thia vent bit i will vacuum the crud around it.
    The last photo is an exhaust vent I think.
    20200216_081749.jpeg 20200216_081744.jpeg 20200216_081737.jpeg Image%20(2).jpeg Image%20(3).jpeg Image%20(4).jpeg Image%20(5).jpeg
  9. bisco
    51,142
    A little of this and a little of that, and Prius overreact
  10. davecook89t
    1,076
    810
    Four Touring
    That is definitely some crud, alright. Was the car driven with the panels taken out for some period of time allowing that stuff to collect? There would normally be nothing there if it had been covered by panels and carpet the whole time. The fan can survive a little bit of dust, although if it is covered with it, its efficiency will be reduced. Some of that stuff looks like gravel. If that got into your fan that would be a little more serious. You didn't say that you heard anything rattling when your fan was running, but it's definitely worth checking if you are going back in to make sure the ducts are lined up properly. (Removing the side panel should not have changed the alignment of the ducts, so it's hard to see how your working on the taillight would have affected that).
    If turning off the car and letting it rest for awhile before you drive it again reduces the fan noise, I think that is another indication the battery is heating up as it charges, which is not a good sign. I've been advised not to "freak you out" about the battery, but I do think it would be worthwhile to get hold of an OBDII scanner (available online for $10 - $15, make sure to get one with the ELM 327 chip) and the Dr. Prius or Hybrid Assistant or Torque app on your phone to see if there is anything going on with your battery that might be a concern.
    nssdiver and Graeme1949 like this.
  11. PriusCamper
    PriusCamper Senior Member
    12,058
    4,893
    Pacific Northwest, USA
    So sick of irrational ill-informed fear making from people who don't know how a Prius normally operates. If you don't know how to repair hybrid batteries or don't know how the system regulates it's temperature, please don't post "advice" about how you think its failing... It's not helpful to anyone.
    Graeme1949 likes this.
  12. davecook89t
    1,076
    810
    Four Touring
    I guess I should have left out the "possibly on the verge of failure" part. Apologies to the OP for unnecessarily alarming him.
    I did hear the fan on running on our Gen 2 once after we had climbed Mount Charleston near Las Vegas. I shut down the car and half an hour later when I put it back in 'Ready' mode I heard the fan roaring. Checking the Torque app I saw all 3 of the temperature sensors reading near 50 degrees C. I believe the middle one showed 56.4. I really did think the battery was toast. That was 2 and half years ago and although I know the battery is weakening, it still has not thrown a code. I guess it's important to know what conditions resulted in the fan running at full blast. I've driven the car enough to know it is not normal. In my case, I believe heat soak accounted for our issue, lacking a better explanation.
  13. Vman455
    Vman455 Senior Member
    537
    553
    The Middle
    I assume you bought this used? Because that isn't a 2011; the Gen 3 Prius does not duct the battery fan to the pressure relief vent at the back of the car.
    That said, if you can hear the battery fan occasionally then you know it's still working. I hear mine quite often in the summer.
  14. Gnarly
    Gnarly Member
    142
    44
    No, the panel was only removed during the taillight replacement. My oldest who sits back there when we're driving didn't hear it come On today. I had the dealership replace that hybrid battery and it's probably 20k miles already.
    It's my wife's car and she bought soil for the garden and left there for a week, or she would argue that "I" left it there.
    Graeme1949 and davecook89t like this.
  15. Gnarly
    Gnarly Member
    142
    44
    sorry, did I post on the 2nd Gen or the 3rd Gen originally. My bad.
  16. Calimobber
    Calimobber Member
    94
    83
    Death Valley
    Why did this get moved to the 3rd gen section? the pictures clearly show a 2nd gen prius.
  17. ASRDogman
    ASRDogman Senior Member
    7,233
    3,774
    ?? your bad, what???? (n)
  18. Gnarly
    Gnarly Member
    142
    44
    I misunderstood Vman's reply. I read that my post was moved and then at the same time his reply was that my pics weren't a 2011 Prius. it made me second guess where I posted this. disregard.
