Rear running lights are intermittent
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mike Dupont, Dec 3, 2013.
  1. Mike Dupont
    Mike Dupont New Member
    Hi everyone, I was informed by a neighbor today that both of my rear lights are out, turns out it's not the bulbs though.
    After screwing around, pulling the wrong bulb, etc... I closed the trunk with a bit more umph that usually which promptly brought them both on again. The turn signals work fine, the brake lights work fine, the back up white lights look good. So here's what I know or can deduce:
    1. It's not the fuse.
    2. The bulbs are fine.
    3. It must something else.
    Any ideas as to what the something else could be? Has anybody had similar issues? A loose wire would seem likely but I really don't know where to begin following that line of inquiry. Any help or suggestions would be greatly appreciated.
    Mike Dupont
  2. xliderider
    xliderider Senior Member
    7,894
    3,128
    Honolulu, HI
    The metal contacts on the bulb and or bulb socket may have some corrosion. Pull the bulbs and take a pencil eraser or some fine emery sandpaper to the contacts. Then put some dielectric grease on them and reassemble.
    SCH-I535
  3. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    FWIW, those bulbs don't cost a lot, are easy to replace and will blink out and then come back on.
    I would bet if you put in two new bulbs that the problem will go away. Had the same thing on ours, light constantly on and off. Pull bulb, wiggle wires, bang on light the bulb would light up. When I broke down and put in a new one, the problem went away. Those lights have been burning bright now for over a year.
    Try the Sylvania 2825LL bulbs - those work the best for me.
  4. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    Those should be a wedge type base so make sure they're fully inserted into the socket. You will feel a snap when they are in all the way.
  5. Takeshi_Ito
    Takeshi_Ito New Member
    CA
    If the bulbs and the fuse are fine, first clean the bulb mounts of rust and dust. Test it with a working bulb. If it does not come on, test the mount terminals for continuity and voltage supply.
