Rear Seat Belt Connections in backwards???
Discussion in 'Gen 2 Prius Accessories & Modifications' started by NaptownPrius, Mar 16, 2008.
  1. NaptownPrius
    NaptownPrius Getting Greener....
    269
    Napolis, Merlin
    As I was installing my new seat covers, I noticed that the rear set belt connections seem to be in backwards on the left of center rear seat connection.
    The red button to disengage the seat belt is on the underside of the belt when worn, is that normal.
    Here's a picture.
    See how the left connection has the red button on the outside. I had the back seat out and really can't see a way to change this as the seatbelts are seat specific due to different side metal connections on the prong part.
    I tried to see if there was a way t o remove the seatbelt connector bolt and fix this, but the connection is made with a bent piece of metal that only connects as shown.
    If anyone can take a second and look at their back seats, are your connections backwards like mine?
  2. Boo
    Boo Boola Boola Member
    5,051
    476
    97
    Flushing, NY
    I'll check mine and report back to you at around 8:15 pm EDT.
  3. eestlane
    eestlane Member
    110
    Space Coast, FL
    Just switch the two belt receptacle webs in the cushion crack and all will be alright with the world. Then the center belt tongue will fit into the receptacle nearest to it and the left outside belt into the one nearest it. Enjoy, its still just a car.
  4. Boo
    5,051
    476
    97
    Flushing, NY
    Mine are exactly like yours in your picture. The rear center seat's belt latch crosses the rear driver-side seat's belt latch.
  5. NaptownPrius
    269
    Napolis, Merlin
    Not obsessing, clearly just a car....I have a 9 and 12 year old that practically live back there. They complain.
    Easier said than done. The belt connection on the right is very short, no play to speak of between where it attaches to the frame. The center belt has a smidge more belt before attaching at the frame, but not much.
    Simply swapping them really won't work. If I could I'd do it. I tried with the seat removed.
  6. eestlane
    eestlane Member
    110
    Space Coast, FL
    Dear Naptown, I just switched them on mine a little while ago, but I didn't remove the rear seat. I just switched them in the crack and they stayed that way. I can see why your kids complained! Good luck.
  7. ldxcrunr
    ldxcrunr New Member
    25
    Long Island ny
    what kind of seat cover is that did you also do the front?:)
  8. NaptownPrius
    269
    Napolis, Merlin
    They're Wet Okoles I bought off a fellow Priuschat member.
  9. Rest
    Rest Active Member
    1,210
    49
    CA
    Old thread I know, but I just found it and was also wondering why the rear seat connectors are backwards. I've have the rear seat out so, yes they are installed backwards from Toyota. Some have said it was so child seats would install easier, but I don't know for sure.
  10. dot4f
    dot4f New Member
    Phoenix
    I have 2008, and mine too are backwards. Why? I really wish someone could provide a good reason - I'm not really buying the given explanations which seem more like excuses. I can only imagine that if they are all this way, it was done for a reason, but I don't see how they would be any more effective with or without a car seat. Furthermore, why are they keyed at all? That just seems pointless. :)
  11. Rest
    Rest Active Member
    1,210
    49
    CA
    What do you mean by keyed? But I agree with you and hope to get a real answer about this.
  12. qbee42
    qbee42 My other car is a boat
    18,058
    3,054
    Northern Michigan
    The pull angle on the seat belt anchors is important. The seat belt connectors cross to provide a better angle to the anchors. The connectors are keyed to keep the proper angle.
    Tom
  13. Manksgloob
    Manksgloob Member
    243
    My understanding was it gave more room for butts (and carseats).
    Behold, my extremely crude drawing:
  14. Rest
    Rest Active Member
    1,210
    49
    CA
    Okay, but then how does this apply when you have 3 people sitting there?
  15. Rook
    Rook New Member
    Tampa
    I'm glad someone else noticed this. I was trying to put the middle seat belt latch in the slot per the manual, and it just didn't work. And when I noticed that the buckles seemed swapped, I thought something was wrong.
  16. qbee42
    18,058
    3,054
    Northern Michigan
    By overlapping the attachment points you get a slightly more comfortable pull angle. It really only applies when you have three people in the back seat. With two, there is space in between. With three, things get crowded, so the overlap helps.
    Tom
Loading...
