Rear seat modification to fold flat
Discussion in 'Prius v Accessories and Modifications' started by ChaseE, Jan 18, 2025.
  1. ChaseE
    ChaseE Member
    66
    39
    29
    Oregon
    So I finally tore down the sides of the rear seats to determine if there was a way to modify it and make it fold nearly flat, as it's not only necessary requirement for how I haul the product for my business, but would also make setting it up to sleep in much easier.
    There's just a few screws on the side plastic, and then you just pry on the edges until they pop off. Just as I thought, the circular pivot point has a metal stop tab on each end to prevent it moving more forward or reclining too far back...my guess is so that the coil spring does not lose too much tension and bind up causing issues, but I could care less about the convenience of the seat flopping forward on its own.
    The plan is to use my Dremel and cut out a section of the metal at each point on each side, and then test the seat angle.
    I'll get the necessary supplies at the hardware store tomorrow and hopefully have an update.
  2. ChaseE
    ChaseE Member
    66
    39
    29
    Oregon
    UPDATE: got a fiber reinforced metal cut-off wheel for my Dremel at Lowe's today...this was much easier than I thought it was going to be! Took about 2 minutes per side on the first small seat to cut a diagonal angle as you can see in the picture.
    The result? The seat now goes completely flat without compromising functionality, other than keeping the coil spring removed so you have to move the seat down yourself instead of assistance from the spring tension.
    Now I just have to do the other seat, and put all the plastic back on. All in all a pretty quick modification once I figured out what I needed to do. To use this for hauling cargo that needs to stay flat and occasional using it to sleep in while maintaining use of the seats.
  3. ChaseE
    ChaseE Member
    66
    39
    29
    Oregon
  4. Air_Boss
    Air_Boss Senior Member
    4,220
    1,188
    New Yawk
    Why leave the springs out?
  5. ChaseE
    ChaseE Member
    66
    39
    29
    Oregon
    Because if you relieve too much tension on the spring, it can fall out of the bracket causing it to bind up... Probably the reason why they created that metal tab stop in the first place. They only had so much circumference to work with, so they chose a thicker more durable spring instead of a thinner one that might break over time but would allow more freedom of movement.
    Air_Boss likes this.
  6. ChaseE
    ChaseE Member
    66
    39
    29
    Oregon
    Now that I know the maximum efficiency configuration to load cargo, I'm now determining what's possible for sleeping. Now that the seats go flat, I can use the old Gen 2 Prius trick of sliding the front seats forward and reclining all the way back as you can see in the image...this gives you 73in in length to work with for a mattress pad.
    Bobkyou and vvillovv like this.
  7. Dan H
    Dan H Junior Member
    47
    27
    Miami FL
    2015 Prius v wagon
    Wow! Amazing job. I always hated that the seats did not fold flat. I just removed mine completely for maximum cargo space.
    ChaseE likes this.
  8. Mr Cleeb
    Mr Cleeb Junior Member
    Nevada
    2017 Prius v wagon
    I love this, and am looking forward to doing it with the passenger side rear seat ... thank you for this!!
    ChaseE likes this.
  9. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Hello.
    So I am trying to do this same mod you did in my 2012 Prius V and I ran into a problem. I cut the metal part on the smaller of the two rear fold down seats.
    However, on the larger fold down section, I cut one side successfully, but the other side seems to be place in the middle of the seat instead of on the end. And also it looks like its one big section and I am confused on how to access the other side to cut the metal?
    Is it possible to separate the larger part into two sections? I'm not sure what I have to do.
    @ChaseE
  10. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Is there anyone that can help me with this??
  11. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    I'm really at a loss. I don't know how to access the middle hinge area to cut the metal. Can someone please point me in the right direction? Like to I have to disassemble the whole seat somehow? Do you know how to remove the plastic panel on the rear side of the backrest? I feel like that would give me more clearance. Its really stuck on there strong.
    [​IMG][​IMG]
  12. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Ok. We managed to cut the last piece of metal on the longer bench rear seat. Thank god we didn't have to disassemble the seat. We had to pry open the plastic pieces and hold them open with various tools. Once it was open wide enough I was able to get in there with my green Ryobi dremel and a regular sized ceramic cutting disc. I did scuff the rubber a bit but not too much. It took a while but I cut down from the top first vertically, then horizontally against the metal. Once it was weak enough I was able to bend it back and forth and break it off with a pair of channel locks. After the metal broke off it was fairly easy to form and clip the plastic/rubber pieces back together to their original position.
    All in all its much flatter now than previously. There is still a slight bit of an angle but not as pronounced as before. Hope this helps anyone attempting this and runs into the same issue.
    Next what I want to do is build an unfolding wooden platform which I can place in the back and make a bed. Will post on that later in a different thread.
  13. Air_Boss
    4,220
    1,188
    New Yawk
    Persistence paid off!
