Rear Shocks
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by SnT08Prius, Sep 16, 2021.
  1. SnT08Prius
    SnT08Prius Active Member
    158
    187
    Bozeman, Montana
    So the prius is now at 367,000 miles and in need of a little love.
    The start of this process is the rear shocks as 1 has been leaking for about 5 years and has the car acting up a little on the bigger bumps. I got some cheaper complete units so I did not need a spring compressor.
    Job went ok until the very last bolt... changed the way I held the hammer drill and inadvertently changed the direction from undo to do up... sadness.
    had to pay a mechanic that could get the rounded head bolt out ($124) and job complete.
    Next is the front shocks and ball joints.
    I also have 5 battery cells to work over the HV battery once I can get the torque pro to work.
    #1 SnT08Prius, Sep 16, 2021
  2. Sonic_TH
    Sonic_TH Active Member
    574
    96
    Puerto Rico
    2016 Prius c
    Your hybrid battery is the factory one?
