Rear spoiler, is it glued on?
Discussion in 'Gen 3 Prius Technical Discussion' started by Anthony, Oct 1, 2009.
  1. Anthony
    Anthony New Member
    103
    Pacific Northwet
    While taking some pictures today I noticed my rear spoiler moves quite a bit, it feels like it is attached with double sided tape. I searched for any issues on here, but I did not find any dedicated to this issue. Anyone else have an issue or should I go see the dealer?
  2. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Mine has some flexibility and I'm a bit concerned about running it through a car wash, which I will have to do once the salt hits the roads here in the Midwest. Unfortunately, I don't have any touchless car washes around here either.
  3. TonyPSchaefer
    14,816
    2,496
    66
    Far-North Chicagoland
    My '04 has some give when I work on it. So I simply don't. I don't know how it's attached but I would certainly not use it to shut the hatch.
    Someone's gotta have a parts book with an illustration.
  4. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Mine has a lot of play as well, and I have wondered about how well it's attached
  5. Mark57
    2,945
    2,735
    OK
    Mine is relatively tight. At most there's 1mm of play at the back edge.
  6. donkitchen
    donkitchen Junior Member
    50
    Mt Airy, MD
    I noticed the same thing. Definitely made me think it had more play than it should have. Glad at least to hear it's not just my car...
  7. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    It's active aerodynamics. When you drive faster, the spoiler is pushed down by the downforce to reduce drag.... just kidding. Mine has some give to it also. Afraid that I might break it one of these days when I'm polishing it.
  8. dfran1
    dfran1 New Member
    89
    17
    MA
    Both of my 2010 Prius's (IV and V) have the same play to it, yes it does feel weak and a click sound (or something, when moved enough). So I think they are all like this.
    Don
  9. Tideland Prius
    16,054
    Good question. I don't know. Both of ours have some play in it. I never use it to close the hatch.
  10. patsparks
    10,664
    567
    Adelaide South Australia
    It is held on with clips and screws.
  11. Tideland Prius
    16,054
    So it technically should be strong?? but the amt. of play in the spoiler don't seem to suggest that.
  12. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    However the scarcity of posts telling of spoilers breaking off seem to support it. I guess it is "strong enough".
  13. dan2l
    dan2l 2014 Prius v wagon
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Is it easy to tighten the screws?
  14. patsparks
    10,664
    567
    It shouldn't need tightening. Don't use the spoiler as a handle to close the hatch, it isn't mean't for that, I push on the Toyota emblem, it never lets me down.
  15. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    What is wrong with using the handholds on the inside?
  16. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    Nothing wrong with that. But at some point your hand will have to touch the outside, so that would amount to two steps. Most people, if they're tall enough, prefer the one step of pulling down on the outside somewhere. Either way, it's not a good idea to use the spoiler as a grab.
    Personally, I like to use an L shaped handle that attaches to the bottom two holes of the rear license plate. These L shaped handles were first made for European wagons and hatchbacks like Volvo, Saab, BMW and Mercedes. Here's a picture of one:
    Among the places you can get it is Ultimate Cupholders for $16.50:
    SAAB Trunk Handle for BMW - Ultimate Cupholders - Cup holders for 5 Series and 7 Series BMW, Z4, Porsche Boxster / Porsche 911 996, Mercedes, Audi, Acura NSX and other fine cars. The ultimate cup holder / cupholder!
    3 people like this.
  17. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    I close it by pulling down on the handhold on the inside halfway and the door/gravity does the rest of the work. Try it. Works every time once you get a sense how hard to pull, which isn't much. No need to touch anything on the outside.
  18. Boo
    5,051
    483
    97
    Flushing, NY
    I had tried that on my Gen II when I first realized there was an inside handhold, and it didn't seem to work or work easily (maybe the Gen III hatch is better for closing that way :confused:).
    But I will try again per your advice, so thanks.
    But even if it works like you said, I suspect I'm going to prefer pulling down the hatch from the outside because I think it's easier and I've been doing it that way for the past 36 years.
  19. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    Maybe it doesn't work as well on the Gen II. Perhaps someone who has both can tell us if it works better on Gen III than Gen II.
  20. Tideland Prius
    16,054
    The Gen 3 closes a LOT easier than the Gen 2. The Gen 2 has more resistance and thus requires more force to close. Those of shorter stature may not have the required strength to close it in one go. Heck, even I have trouble from time to time although my issue is the opposite. It's getting my hand out of the wy before it closes on me because my arm will be nearly parallel.
    On the Gen 3, the struts cut out when the rear window is approximately horizontal thus we don't need as much effort to close it. I can just flick it down and as long as I get past that threshold, the hatch will close on its own.
