rear springs
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by novaz, Jun 20, 2019.
  1. novaz
    novaz Junior Member
    47
    arizona
    2015 Prius c
    I have just replaced the rear shocks on m 2015 prius c and was thinking about replacing the rear springs now I live off grid so don't have very good working area but make do best I can is it a difficult job and do I need spring compressors cant seem to find youtube vids for the C
    Thanks
  2. Bryce Husserl
    Bryce Husserl Junior Member
    28
    27
    2016 Prius c
    I would suggest you use spring compressors, people have gotten seriously hurt without using them. However if you have a car Jack and compressor springs, it's a few bolts off the back springs and it's a little more in depth with the front.
  3. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    Why would you need to replace springs on a 2015 car? Car coil springs last decades of abuse before beginning to sag.
  4. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    Removing the rear springs is as easy as disconnecting the damper lower bolts and letting the torsion beam droop. Pull old springs out, put new ones in. But I agree with the above--why on earth do you want to replace 4-year old springs?
  5. lech auto air conditionin
    830
    601
    261
    san francisco
    If you need more load carrying over bumps just add Firestone load air bags inside the spring it easy only a few minutes i suggest lube them up with lots of dish soap makes it much easier.
    I filled mine with nitrogen just because I have it as part of my job supplies. Only 5 PSI when empty upto 30 PSI full load.
    Daly I have over 800 lb minimum we’ll over 1000 lb to 1200 lb plus a trailer when fully loaded going to a big job.
