Rear stop light issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jayw13702, Jul 8, 2013.
  1. Jayw13702
    Jayw13702 Active Member
    142
    170
    Plymouth UK
    Hi guys,
    I have a 2004 T3 that i have had for about 3 months now, it was bought with 106,000 miles on it and i have added about another 10000 in the time i have had it.
    It has been totally reliable and that's a big ask as i'm using it as a taxi so it gets a bit of a hammering.
    A couple of days ago i noticed the driver side stop light was not working, being LED i knew it was not going to be a simple fix so i checked the fuses, wiring, Printed circuit board and all was good, there was/is 12 volts running to the LED bulb unit and when the ignition is on you can see the bulb is very faint when the brake pedal is pressed.
    I instantly think the unit is faulty, after all i have 12 volts right up to the bulbs, so i order a brand new unit and am waiting for it to arrive.
    Tonight i am driving, my partner is behind me in her car and when we get home she tells me the drivers side light is now working (y) but the passenger side is not:mad: .
    I strip out the light unit and the symptoms are identical as the drivers side one, 12 volts right the way through to where the wire goes into the LED bulb housing, with the ignition on and brake pedal pressed it is glowing at about 1/2 brightness :( i am now at a total loss as to what the problem is.
    Can anyone help with any ideas please, i am desperate as the car has an inspection in 2 days and i need this issues totally resolved
    Thank
  2. Patrick Wong
    18,200
    6,474
    Check the ground wiring from the LED bulb assembly. It could be that a loose ground connection is introducing added resistance which causes the LED lights to glow at a dimmer-than-normal intensity.
  3. mff
    mff Junior Member
    I am having the same problem on a 2009- checking power at the quick disconnect circuit board show 13.6V at CN1, and 13.1V at CN2 and of course a good ground- how can I check the circuit board? can you wire around the PCB?
  4. Jayw13702
    142
    170
    Plymouth UK
    I ended up replacing the lamp assembly.
    My readings were the same as yours, I tried different earth points, even tried putting a new earth wire in, all to no avail.
    Behind the led bulbs must be another printed circuit board that you cannot get at, this must be the issue point
  5. Patrick Wong
    18,200
    6,474
    Although I have not needed to disassemble the taillight assembly I believe you are correct. That PCB may also contain current-limiting resistors.
