Rear suspension compatibility
Discussion in 'Gen 4 Prius Accessories and Modifications' started by WH525, Oct 5, 2023.
  1. WH525
    WH525 New Member
    Alabama
    2023 Prius
    I’m trying to put a 2 inch hitch on my GEN 4 (2023)Prius LE. I was told another model of Toyota has rear struts that are stiffer that will bolt right on to my Prius. Does anybody know if this is correct and if so what model Toyota?
  2. Drakxyfly
    Drakxyfly Junior Member
    112
    24
    Usa
    2021 Prius
    The 2019+ Corolla uses the same shocks. The only option you have is Tein. This is the part number for EnduraPro kit; VSTK6-A1DS2. The only place I found that carries them in stock is pro import tuner, they sell the front and rear separately.
    Shocks for 2021 Toyota Prius Hatchback LE FWD
    This is all providing you have a 4th Gen vehicle. The 2023 Prius is a Fifth Gen not a Fourth Gen. So either you have a 2022 Prius or you have a Fifth Gen, (unless they kept making it in a different country I'm not aware of.)
    #2 Drakxyfly, Oct 6, 2023
  3. WH525
    WH525 New Member
    Alabama
    2023 Prius
    No, I fat fingered that. It’s a 2022. And thank you, I thought it was Corolla but needed to make sure.
    Drakxyfly likes this.
  4. Drakxyfly
    112
    24
    Usa
    2021 Prius
    Cool just making sure because I haven't researched the 23. I almost got a fifth gen but got such an incredible deal on the 21 I found. I just got done putting the Tein EnduraPro kit on and RS-R springs, so I just did all this research less than a month ago.
    WH525 likes this.
