Rear suspension
Discussion in 'Gen 2 Prius Accessories & Modifications' started by daley, Oct 6, 2019.
  1. daley
    daley Junior Member
    Knoxville
    can anyone suggest a good upgrade for rear suspension?
    My Prius has 225k miles and still going strong but when I add a bit of weight in the rear it really drops.
    I’d like a stiffer/taller set up in the back as I often carry weight. I don’t want to spend a huge amount on air or anything. Is there a good replacement coil over that is an improvement to stock?
  2. PriusCamper
    PriusCamper Senior Member
    11,119
    4,527
    Pacific Northwest, USA
    Well... I already spent too much time on this exact same problem. When it comes to matching up springs and shocks the way they do in performance cars, the process doesn't translate so well to an economy car. For one, the price point is ridiculous.
    However, there are people in the business that know the parts system well enough to get a identical mounting, or at least a mount that can be re-welded for your car, but with slightly stiffer springs that will fit. Of course it may harm cars handling at freeway speed. Won't know until you try I guess... As in I spent so much time thinking about all the factors and got discouraged. But hopefully others will come along with some thoughts that are more encouraging?
  3. artrockets
    artrockets Member
    39
    39
    225k..? have you ever replaced the struts/springs? Iv hauled and towed a lot with mine(191k) and just this year replace all 4.. so much better..
    Literally felt like a brand new car, except for all the rattles n squeaks and the crack in dash vent.
    ydpplqbd likes this.
  4. daley
    daley Junior Member
    Knoxville
    No I haven’t replaced any suspension parts. I would like to but was wondering what options there were.
    I also live up a gravel road so I think some lift might help.
  5. artrockets
    artrockets Member
    39
    39
    I don't think there are many options for the Prius.. When I was looking to replace my struts the more expensive stuff looked exactly the same as the cheaper stuff..
  6. Kaptainkid1
    Kaptainkid1 Active Member
    308
    243
    Los Angeles
    I used lift helper springs for $12 at autozone.
    Easy to install and cheap good mod for extra weight in the Prius. IMG_20200108_225814.jpg 20191230_142744.jpg 20191230_143518.jpg 20191230_145732.jpg 20191230_150927.jpg 20191230_151258.jpg 20191230_151148.jpg 20191230_151534.jpg
    SM-J737T1 ?
  7. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    If you have inspections this isn't a good option. At least it wouldn't go through yearly inspection here.
    It will also cause uneven and more force on the spring. That will make it more likely to have a spring failure in the future. Which is why it won't go through the inspection.
  8. Kaptainkid1
    308
    243
    Los Angeles
    Well I choose this mod because it works and it's cheap. Honestly I just drove 3000 mile camping trip with fully loaded thule box roof rack, trunk and back seat for winter camping trip.
    I have towed bikes, gear and trailers for many years and hauling heavy loads in cars and trucks you come to realize in all case the safety and stability in any vehicle comes with correct height of the rear springs needs to be adjust properly when adding weight and towing.
    So knowing in advance I was going to haul lots of gear I installed helper lift spring made the world of difference. Honestly an hour of work and $12 for parts has made my Prius safer on the road, I would highly recommend this mod for all Prius drivers who haul any heavy load like 4 people in the car. That's why fully loaded and at 103mph the car was very stable and predictable. No floating or bouncing just very firm and controlled.
    Obviously this mod can only be done countries that allow it of course.
    If you wanted to replace it with heavy spring I read Toyota Matrix rear spring are better for extra weight.
    Second photo shows my car without the helper lift spring mod with 10x case of water in the trunk and back seat.
    The top photo shows fully loaded with camping gear and 2 people. No compressed springs.
    SM-J737T1 ?
    View attachment 184963 View attachment 184964
    #8 Kaptainkid1, Jan 12, 2020
  9. valde3
    2,002
    745
    Finland
    Yes. I'm not saying that it wouldn't work. Or that springs would fail, it's just more likely for them to fail than without the mod.
  10. ydpplqbd
    ydpplqbd Active Member
    542
    250
    I think that I saw a thread on here about using springs (and perhaps struts) from a 4WD vibe. Seemed like a pretty solid set-up as the vibe springs appear much more heavy duty.
    I have been looking at doing the same type of beef-up of rear suspension. As I intend to install a trailer hitch and tow ocassionally.
    #10 ydpplqbd, Jan 13, 2020
  11. PriusCamper
    11,119
    4,527
    Do you know where that thread is? I've not seen it yet, but would like to see it.
  12. ydpplqbd
    542
    250
    I am on the road right now. When I get home tonight I will look for the AWD Vibe thread. In the meantime I have ordered the RR strut assembly ( fully loaded) from Advance Auto for: i. Gen2 Prius, and ii. 2009-10 AWD Pontiac Vibe. Expect lots of pics, comparisons and measurements of the two setups.
    Aaron Vitolins likes this.
  13. PriusCamper
    11,119
    4,527
    Awesome... Thanks... Looking forward to this!!!
  14. ydpplqbd
    542
    250
    Link to Vibe/Matrix Spring thread: Heavy Springs And Lift Upgrade | PriusChat
    Next Tuesday 01212020 (M is a holiday), I should be receiving the fully loaded RR strut assemblies from Advance Auto for: i. Gen2 Prius, and ii. 2009-10 AWD Pontiac Vibe. Expect lots of pics, comparisons and measurements of the two setups. My intention is to swap the whole Vibe AWD strut assembly into my Gen2. But only after I make sure all the particulars are the same except for spring rate and spring thickness.
    Alternatively, if there are substantial differences then I will likely just use the AWD Vibe springs on new Gen2 rear struts with the spring perch modification described in the link above (or perhaps use the Vibe springs on new Vibe rear struts with Prius bearing mounts at the top of the strut -we shall see).
    #14 ydpplqbd, Jan 14, 2020
  15. ydpplqbd
    542
    250
    Vibe AWD RR strut and Prius Gen2 RR struts came in a little sooner than expected. Vibe top bearing assembly looks like it would bolt in BUT the Vibe strut assembly appears to not have enough travel and be the wrong overall length. Take a look and let me know your thoughts.
    Monroe 172394R Complete Strut Assembly for 2006 Prius RR
    Compressed Length: 12.560in.
    Travel: 6.260 in
    See: Advance Auto Parts - Down for Maintenance
    My measurement from bearing surface top to center of bottom eye: about 16 1/4"
    Monroe 172600R Complete Strut Assembly for 2009 Pontiac Vibe AWD
    Compressed Length: 11.452 in
    Travel: 2.422 in
    My measurement from bearing surface top to center of bottom eye: about 13".
    IOW, the Prius strut assembly is about 3 1/2" LONGER than the 2009 AWD Vibe RR strut assembly with about four ("4") additional inches of travel.
    PS Last picture has full picture of both strut assemblies. Near the top of each strut assembly is a piece of blue tape with the Monroe part numbers on them.
    Pics set forth below:
    01172020_stru8.jpg 01172020_stru7.jpg 01172020_stru6.jpg 01172020_strut5.jpg 01172020_strut4.jpg 01172020_strut3.jpg 01172020_strut2.jpg 01172020_strut1.jpg
    #15 ydpplqbd, Jan 17, 2020
  16. Kaptainkid1
    308
    243
    Los Angeles
    So this mod isn't going to work?
    SM-J737T1 ?
  17. ydpplqbd
    542
    250
    This is not a bolt-in alternative. However, you could try either of the following:
    1. use AWD Vibe spring on a stock* 2nd gen Prius strut and bearing cap; or
    2. Buy, or fabricate, strut extender to make up for the 3 1/4" shorter length when using the Vibe AWD strut assembly.
    See (similar shock extender for Jeep Wrangler - concept only): 2007-2017 Wrangler JK Front Shock Extender Kit For 2-4" Leveling Kit | eBay
    *- other Priuschat thread describes moving Vibe spring perch to Prius strut. See: Heavy Springs And Lift Upgrade | PriusChat
    #17 ydpplqbd, Jan 19, 2020
  18. strawbrad
    953
    1,000
    That other thread is mine. I have a few thousand miles on the new struts. The car rides better with a heavy load than it does empty. My friend drove his car from MN to Mexico with just the heavy rear springs. He says the car handles better loaded than it ever has. Next I'm going to try lowering tire air pressure to 32 psi for when the car is empty.
    You bought a few more parts than needed. To make this work take the springs and bottom spring perch from the Matrix 4WD struts and install them on the Prius struts.
  19. ydpplqbd
    542
    250
    I purchased the two fully loaded struts (namely, for 2009 AWD Vibe RR and 2006 Prius RR) as a comparison of the two strut assemblies. My hope was to bolt in the 2009 AWD Vibe assembly. 2009 AWD RR strut assembly will not work because it is about 3 1/4" shorter and has about 4" less travel.
    Both strut assemblies have been returned to the auto parts store for full refund. Now, I am on the hunt for a pair of rear strut assemblies from 2009-2010 AWD Vibe. With the idea of emulating your build by: i.) reusing AWD Vibe springs; and ii.) reusing AWD Vibe spring perches.
    IOW, still working on this project.
